I am interested in using the Data Logger Shield and was wondering what is the maximum channel voltage it could handle as data input? I can't seem to find this information but may be obvious to some already. I need it to handle up to 15 volts ideally in a battery monitoring project.
Thanks in advance,
Jim
Data Logger Shield Maximum input voltage
Re: Data Logger Shield Maximum input voltage
If you are using the analog input pins on your processor, then it will depend on the processor you are using.
In general, 5v processors like the Arduino UNO can tolerate up to 5v on the analog pins. 3.3v processors like the Arduino Zero can tolerate up to 3.3v.
If you want to measure a higher voltage than your processor will tolerate, you can divide it down using a voltage divider: https://en.wikipedia.org/wiki/Voltage_divider
- millercommamatt
The shield just provides an SD card, a real time clock, a 3.3 voltage regulator, and a prototyping area. The input limits on the analog in pins are determined by the Arduino board. Those limits are 5 V max input.
Someone else might have a better solution for you but maybe this will meet your needs: https://www.adafruit.com/product/904
- jshep1956
Thank you for the information about the maximum voltage of the Arduino and Voltage Divider suggestion. That is just what I needed.adafruit_support_bill wrote:If you are using the analog input pins on your processor, then it will depend on the processor you are using.
- jshep1956
millercommamatt wrote:The shield just provides an SD card, a real time clock, a 3.3 voltage regulator, and a prototyping area. The input limits on the analog in pins are determined by the Arduino board. Those limits are 5 V max input.
Good to know. Thanks for the information.
