Problems Initializing SD Card with Adafruit datalogger shiel
by OwenSmith on Fri Feb 01, 2019 7:44 pm
Hi, I am trying to get an 8gb SD Card initialized using an Adafruit datalogger shield (newer version) with the built in "CardInfo" program, but I am having no luck. Whenever I attempt to run the program, I get the following error:
 Initializing SD card...initialization failed. Things to check:
* is a card inserted?
* is your wiring correct?
* did you change the chipSelect pin to match your shield or module?
So far I have tried the following:
-Changing the chipSelect pin to 10
-Downloading and installed the most recent version of the SD Card library
-Replacing all of my components (datalogger shield, Arduino Uno, SD card) with new ones.
I formatted the 8gb SD card through: https://www.sdcard.org/downloads/formatter_4/
I am using an Arduino Uno and Arduino IDE version 1.8.7 for reference.
OwenSmith
Re: Problems Initializing SD Card with Adafruit datalogger s
by adafruit_support_bill on Fri Feb 01, 2019 8:08 pm
Please post some clear photos showing your soldering to the shield.
by OwenSmith on Sat Feb 02, 2019 6:50 pm
OwenSmith
by adafruit_support_bill on Sun Feb 03, 2019 7:33 am
Excellent photos. Thanks. I don't see any problems with the assembly.
Is the UNO you are using an R3 or later UNO (Earlier UNO versions lack the SDA and SCL pins next to the AREF pin).
by OwenSmith on Mon Feb 04, 2019 4:26 pm
Hi, sorry for the late response, but yes I am using an Arduino Uno R3 from Sparkfun
https://www.sparkfun.com/products/11021
OwenSmith
by adafruit_support_bill on Mon Feb 04, 2019 4:49 pm
In this line of the CardInfo sketch:
if (!card.init(SPI_HALF_SPEED, chipSelect)) {
Try changing SPI_HALF_SPEED to SPI_QUARTER_SPEED
