2.8" TFT Touch Shield Tutorial Code problem
by Blueshark on Sat Feb 02, 2019 7:02 pm
Everything was working right until the displaying images part, the example code will not work.
using this TFT shield...
https://www.adafruit.com/product/1651
following this tutorial....
https://learn.adafruit.com/adafruit-2-8-tft-touch-shield-v2/drawing-bitmaps
All libraries have been installed right...
For FORUM use I had to change the name of one of the pictures because the Forums says its a word that is banned in the Forums, the new name is "fox.bmp"
Here is the example code giving me the problem....
    // Adafruit_ImageReader test for Adafruit ILI9341 TFT Shield for Arduino.
// Demonstrates loading images to the screen, to RAM, and how to query
// image file dimensions.
// Requires three BMP files in root directory of SD card:
// purple.bmp, parrot.bmp and fox.bmp.
#include <SPI.h>
#include <SD.h>
#include <Adafruit_GFX.h>         // Core graphics library
#include <Adafruit_ILI9341.h>     // Hardware-specific library
#include <Adafruit_ImageReader.h> // Image-reading functions
// TFT display and SD card share the hardware SPI interface, using
// 'select' pins for each to identify the active device on the bus.
// Hardware SPI pins are specific to the Arduino board type and
// cannot be remapped to alternate pins.  For Arduino Uno,
// Duemilanove, etc., pin 11 = MOSI, pin 12 = MISO, pin 13 = SCK.
#define SD_CS   4 // SD card select pin
#define TFT_CS 10 // TFT select pin
#define TFT_DC  9 // TFT display/command pin
Adafruit_ILI9341     tft    = Adafruit_ILI9341(TFT_CS, TFT_DC);
Adafruit_ImageReader reader;     // Class w/image-reading functions
Adafruit_Image       img;        // An image loaded into RAM
int32_t              width  = 0, // BMP image dimensions
                     height = 0;
void setup(void) {
  ImageReturnCode stat; // Status from image-reading functions
  Serial.begin(9600);
#if !defined(ESP32)
  while(!Serial);       // Wait for Serial Monitor before continuing
#endif
  tft.begin();          // Initialize screen
  Serial.print(F("Initializing SD card..."));
  if(!SD.begin(SD_CS)) {
    Serial.println(F("failed!"));
    for(;;); // Loop here forever
  Serial.println(F("OK!"));
  // Fill screen blue. Not a required step, this just shows that we're
  // successfully communicating with the screen.
  tft.fillScreen(ILI9341_BLUE);
  // Load full-screen BMP file 'purple.bmp' at position (0,0) (top left).
  // Notice the 'reader' object performs this, with 'tft' as an argument.
  Serial.print(F("Loading purple.bmp to screen..."));
  stat = reader.drawBMP("/purple.bmp", tft, 0, 0);
  reader.printStatus(stat);   // How'd we do?
  // Query the dimensions of image 'parrot.bmp' WITHOUT loading to screen:
  Serial.print(F("Querying parrot.bmp image size..."));
  stat = reader.bmpDimensions("/parrot.bmp", &width, &height);
  if(stat == IMAGE_SUCCESS) { // If it worked, print image size...
    Serial.print(F("Image dimensions: "));
    Serial.print(width);
    Serial.write('x');
    Serial.println(height);
  // Load small BMP 'fox.bmp' into a GFX canvas in RAM. This should fail
  // gracefully on Arduino Uno and other small devices, meaning the image
  // will not load, but this won't make the program stop or crash, it just
  // continues on without it. Should work on Arduino Mega, Zero, etc.
  Serial.print(F("Loading fox.bmp to canvas..."));
  stat = reader.loadBMP("/fox.bmp", img);
  delay(2000); // Pause 2 seconds before moving on to loop()
  for(int r=0; r<4; r++) { // For each of 4 rotations...
    tft.setRotation(r);    // Set rotation
    tft.fillScreen(0);     // and clear screen
    // Load 4 copies of the 'parrot.bmp' image to the screen, some
    // partially off screen edges to demonstrate clipping. Globals
    // 'width' and 'height' were set by bmpDimensions() call in setup().
    for(int i=0; i<4; i++) {
      reader.drawBMP("/parrot.bmp", tft,
        (tft.width()  * i / 3) - (width  / 2),
        (tft.height() * i / 3) - (height / 2));
    delay(1000); // Pause 1 sec.
    // Draw 50 Welsh dragon flags in random positions. This has no effect
    // on memory-constrained boards like the Arduino Uno, where the image
    // failed to load due to insufficient RAM, but it's NOT fatal.
    for(int i=0; i<50; i++) {
      // Rather than reader.drawBMP() (which works from SD card),
      // a different function is used for RAM-resident images:
      img.draw(tft,                                    // Pass in tft object
        (int16_t)random(-img.width() , tft.width()) ,  // Horiz pos.
        (int16_t)random(-img.height(), tft.height())); // Vert pos
      // Reiterating a prior point: img.draw() does nothing and returns
      // if the image failed to load. It's unfortunate but not disastrous.
    delay(2000); // Pause 2 sec.
Here is the error messege I get....
   Arduino: 1.8.5 (Windows 10), Board: "Adafruit Metro"
In file included from C:\Program Files (x86)\Arduino\libraries\Adafruit_ImageReader/Adafruit_ImageReader.h:17:0,
                 from C:\Users\alex2\AppData\Local\Temp\arduino_modified_sketch_116188\ShieldILI9341.ino:11:
C:\Program Files (x86)\Arduino\libraries\Adafruit_GFX/Adafruit_SPITFT.h:71:18: error: 'RwReg' does not name a type
         volatile RwReg *mosiport, *misoport, *clkport, *dcport, *csport;
C:\Program Files (x86)\Arduino\libraries\Adafruit_GFX/Adafruit_SPITFT.h:72:9: error: 'RwReg' does not name a type
         RwReg  mosipinmask, misopinmask, clkpinmask, cspinmask, dcpinmask;
C:\Users\alex2\AppData\Local\Temp\arduino_modified_sketch_116188\ShieldILI9341.ino: In function 'void setup()':
ShieldILI9341:54: error: no matching function for call to 'Adafruit_ImageReader::drawBMP(const char [12], Adafruit_ILI9341&, int, int)'
C:\Users\alex2\AppData\Local\Temp\arduino_modified_sketch_116188\ShieldILI9341.ino:54:49: note: candidate is:
In file included from C:\Users\alex2\AppData\Local\Temp\arduino_modified_sketch_116188\ShieldILI9341.ino:11:0:
C:\Program Files (x86)\Arduino\libraries\Adafruit_ImageReader/Adafruit_ImageReader.h:74:21: note: ImageReturnCode Adafruit_ImageReader::drawBMP(char*, Adafruit_SPITFT&, int16_t, int16_t, boolean)
     ImageReturnCode drawBMP(char *filename, Adafruit_SPITFT &tft,
C:\Program Files (x86)\Arduino\libraries\Adafruit_ImageReader/Adafruit_ImageReader.h:74:21: note:   no known conversion for argument 2 from 'Adafruit_ILI9341' to 'Adafruit_SPITFT&'
C:\Users\alex2\AppData\Local\Temp\arduino_modified_sketch_116188\ShieldILI9341.ino: In function 'void loop()':
ShieldILI9341:90: error: no matching function for call to 'Adafruit_ImageReader::drawBMP(const char [12], Adafruit_ILI9341&, int32_t, int32_t)'
C:\Users\alex2\AppData\Local\Temp\arduino_modified_sketch_116188\ShieldILI9341.ino:90:46: note: candidate is:
ShieldILI9341:103: error: no matching function for call to 'Adafruit_Image::draw(Adafruit_ILI9341&, int16_t, int16_t)'
C:\Users\alex2\AppData\Local\Temp\arduino_modified_sketch_116188\ShieldILI9341.ino:103:53: note: candidate is:
C:\Program Files (x86)\Arduino\libraries\Adafruit_ImageReader/Adafruit_ImageReader.h:45:20: note: void Adafruit_Image::draw(Adafruit_SPITFT&, int16_t, int16_t)
     void           draw(Adafruit_SPITFT &tft, int16_t x, int16_t y);
C:\Program Files (x86)\Arduino\libraries\Adafruit_ImageReader/Adafruit_ImageReader.h:45:20: note:   no known conversion for argument 1 from 'Adafruit_ILI9341' to 'Adafruit_SPITFT&'
exit status 1
any help will be apricciated
Cheers...
Blueshark
Re: 2.8" TFT Touch Shield Tutorial Code problem
by Blueshark on Sat Feb 02, 2019 9:35 pm
I found the problem.....
I must have had an old version of the Adafruit ILI9341 library and/or the Adafruit GFX Library, because I just re-installed those files from the Adafruit GitHub repository and now this code works...
Cheers....
Blueshark
by franklin97355 on Sat Feb 02, 2019 11:46 pm
Thanks for letting us know the fix.
franklin97355
