PN532 power problem
PN532 power problem
by zefux on Mon Feb 11, 2019 11:03 am
Hello!
I need to run my PN532 shield in spi mode, and as soon as i close sel0 and 1 as the print says, the power diode stops showing power to the board. is there anything else i need to do then close sel0 and sel1?
zefux
Re: PN532 power problem
by adafruit_support_carter on Tue Feb 12, 2019 2:59 pm
That should be all that's needed. Are you using the supplied jumpers on to the SEL pins?
by zefux on Wed Feb 13, 2019 3:23 am
my version is this, so i have just soldered the 2 shut.
zefux
by adafruit_support_carter on Wed Feb 13, 2019 3:31 pm
Can you post a photo of your actual setup showing how you have everything connected.
by zefux on Thu Feb 14, 2019 4:41 am
zefux
by adafruit_support_carter on Thu Feb 14, 2019 12:44 pm
Try moving power to Vin.
Do you mean the LED does not come on?
by zefux on Fri Feb 15, 2019 4:29 am
The vin didn´t change anything.
yes my indication of something wrong is that the powerled dosn´t light when in spi, but lights fine when in i2c mode.
zefux
by adafruit_support_carter on Fri Feb 15, 2019 12:35 pm
Check and make sure this isn't a solder bridge.
by zefux on Mon Feb 18, 2019 3:28 am
it was a little excess flux so nothing conductive, and it changed nothing to remove it.
zefux
by adafruit_support_carter on Mon Feb 18, 2019 2:49 pm
Check for any other similar shorts since it sounds like some kind of connections issue.
It sounds like you had this working before soldering the SEL jumpers?
by zefux on Tue Feb 19, 2019 3:09 am
Ive had it under a microscope, and cant find a short. and the bord powers up fine in i2c, but i need to run in spi
zefux
by adafruit_support_carter on Tue Feb 19, 2019 1:54 pm
What voltages do you get on the 5V and 3v pins when it is powered via Vin?
by zefux on Wed Feb 20, 2019 3:45 am
when powered via vin i get 3.3 on vin 1.39 on 5v and 0 on 3v
zefux
by adafruit_support_carter on Wed Feb 20, 2019 2:12 pm
Oh. Sorry. I gave you some bad info. I was stuck thinking this was an older breakout version (PID 364) but it's the Arduino Shield version (PID 789).
OK, in that case you want to apply power at the 5V pin. The 3V and Vin pins don't go anywhere. They are not used on the shield version. Sorry about that.
by mshaffer on Thu Feb 21, 2019 12:32 pm
Where can I find the schematic and board layout files for the PID789?
It just links to the PID364.
Thank you.
mshaffer
