Hello....im looking for a replacement for a stepper motor PM422-09
Excitation Method : 4_2
Rated Voltage : 12VDC --- 24VDC
No. of Phase : 4
Step Angle : 7.5°
Coil Resistance : 100 Ohm ± 7% / Phase
Coil Inductance : 59.1mH ±20 / Phase
Step per Revolution : 48
Current : 0.24A / Phase
Holding Torque : >800g.cm
Pull-in Rate : 340pps MIN
Pull-in Torque : 270g.cm at 100pps
Insulation Resistance: 100MΩ MIN at 500VD
Detent Torque : <210g.cm
Rotor Inertia : <9.6g.cm
Stepping Accuracy : 7.5° ± 7 %
Life : 3000h MIN at 20℃
Weight : 136g
Phase 1 : Brown
Phase 2 : Black
Phase 3 : Yellow
Phase 4 : Orange
Common : Red
any suggestions on what a replacement would be or where to get one in the states?
Thank you all
newbie needs help with stepper motor
Re: newbie needs help with stepper motor
I don't know of anything like that offhand. You will probably need some more detail regarding dimensions, mounting hole locations # shaft size. Some useful search terms that might get you closer are:
"unipolar 48-step motor"
That yields plenty of hits - mostly on ebay. Unfortunately, most do not have detailed specifications.
- cocosfunhouse
thank you
- millercommamatt
How close to the specs to things need to be?
By the way, I think the part number is PM4222-09.
That does turn up some more promising leads. This one looks like it would work:By the way, I think the part number is PM4222-09.
https://alhkma.com/pm4222-09-4-phase-un ... per-motor/
- millercommamatt
^ That site is in Iraq.
