I am trying to use the PCF8523 to wake up the Arduino Mega from sleep using the LowPower library. I cannot figure out how to set an alarm and set an interrupt pin for the RTC since it is integrated onto the shield. I am trying to run this code but cannot figure out which pin to set for the RTC interrupt. I know that pin 7 on the RTC is where the interrupts are set, but no documentation on where the pin is mapped on the shield.
// Simple example showing how to set the RTC alarm pin to wake up the Arduino.
// This is a different mode to the alarm clock, which wakes at a particular time.
// This mode is a repeating periodic time, waking the Arduino at fixed intervals.
// Note: this example doesn't wake up the RPi. For that add:
// SleepyPi.enablePiPower(true);
// after arduino wakeup. For a clearer picture of how to do this see the
// eaxmple WakePiPeriodically which wakes the Rpi at fixed intervals.
// To test on the RPi without power cycling and using the Arduino IDE
// to view the debug messages, either fit the Power Jumper or enable
// self-power. http://spellfoundry.com/sleepy-pi/programming-arduino-ide/
// **** INCLUDES *****
#include "SleepyPi2.h"
#include <TimeLib.h>
#include <LowPower.h>
#include <PCF8523.h>
#include <Wire.h>
const char *monthName[12] = {
"Jan", "Feb", "Mar", "Apr", "May", "Jun",
"Jul", "Aug", "Sep", "Oct", "Nov", "Dec"
const int LED_PIN = 13;
// Globals
// ++++++++++++++++++++ Change me ++++++++++++++++++
// .. Setup the Periodic Timer
// .. use either eTB_SECOND or eTB_MINUTE or eTB_HOUR
eTIMER_TIMEBASE PeriodicTimer_Timebase = eTB_SECOND; // e.g. Timebase set to seconds. Other options: eTB_MINUTE, eTB_HOUR
uint8_t PeriodicTimer_Value = 5; // Timer Interval in units of Timebase e.g 10 seconds
// ++++++++++++++++++++ End Change me ++++++++++++++++++
tmElements_t tm;
void alarm_isr()
// Just a handler for the alarm interrupt.
// You could do something here
void setup()
// Configure "Standard" LED pin
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN,LOW); // Switch off LED
// initialize serial communication: In Arduino IDE use "Serial Monitor"
Serial.begin(9600);
Serial.println("Starting, but I'm going to go to sleep for a while...");
delay(50);
SleepyPi.rtcInit(true);
// Default the clock to the time this was compiled.
// Comment out if the clock is set by other means
// ...get the date and time the compiler was run
if (getDate(__DATE__) && getTime(__TIME__)) {
// and configure the RTC with this info
SleepyPi.setTime(DateTime(F(__DATE__), F(__TIME__)));
printTimeNow();
Serial.print("Periodic Interval Set for: ");
Serial.print(PeriodicTimer_Value);
switch(PeriodicTimer_Timebase)
case eTB_SECOND:
Serial.println(" seconds");
break;
case eTB_MINUTE:
Serial.println(" minutes");
break;
case eTB_HOUR:
Serial.println(" hours");
default:
Serial.println(" unknown timebase");
break;
void loop()
SleepyPi.rtcClearInterrupts();
// Allow wake up alarm to trigger interrupt on falling edge.
attachInterrupt(0, alarm_isr, FALLING); // Alarm pin
// Set the Periodic Timer
SleepyPi.setTimer1(PeriodicTimer_Timebase, PeriodicTimer_Value);
delay(500);
// Enter power down state with ADC and BOD module disabled.
// Wake up when wake up pin is low.
SleepyPi.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
// Disable external pin interrupt on wake up pin.
detachInterrupt(0);
SleepyPi.ackTimer1();
// Do something here
// Example: Read sensor, data logging, data transmission.
// Just a handler for the pin interrupt.
Serial.print("hello");
digitalWrite(LED_PIN,HIGH); // Switch on LED
Serial.println("I've Just woken up on a Periodic Timer!");
// Print the time
printTimeNow();
delay(50);
// - Helper routines
void printTimeNow()
// Read the time
DateTime now = SleepyPi.readTime();
// Print out the time
Serial.print("Ok, Time = ");
print2digits(now.hour());
Serial.write(':');
print2digits(now.minute());
Serial.write(':');
print2digits(now.second());
Serial.print(", Date (D/M/Y) = ");
Serial.print(now.day());
Serial.write('/');
Serial.print(now.month());
Serial.write('/');
Serial.print(now.year(), DEC);
Serial.println();
return;
bool getTime(const char *str)
int Hour, Min, Sec;
if (sscanf(str, "%d:%d:%d", &Hour, &Min, &Sec) != 3) return false;
tm.Hour = Hour;
tm.Minute = Min;
tm.Second = Sec;
return true;
bool getDate(const char *str)
char Month[12];
int Day, Year;
uint8_t monthIndex;
if (sscanf(str, "%s %d %d", Month, &Day, &Year) != 3) return false;
for (monthIndex = 0; monthIndex < 12; monthIndex++) {
if (strcmp(Month, monthName[monthIndex]) == 0) break;
if (monthIndex >= 12) return false;
tm.Day = Day;
tm.Month = monthIndex + 1;
tm.Year = CalendarYrToTm(Year);
return true;
void print2digits(int number) {
if (number >= 0 && number < 10) {
Serial.write('0');
Serial.print(number);
