๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday January 20, 2020 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday January 17 will go out Tuesday January 21 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
Move Stepper to certain positions
by RolloBeach on Mon Jul 15, 2019 7:16 am
I am using the Arduino MEGA 2560 and the AF motor shield v2.3. My goal is to define a couple of positions in my sketch and then tell the stepper to go to these positions.
Is there a way to tell stepper the next position, no matter where it actually is? I have a defined starting point, so I can create kind of a table whitch contains the steps from "point zero" to point X.
My main problem is, that I only know the simple commands like "step(200,FORWARD,SINGLE)". Is the AccelStepper library compatible to the v2.3?
I would appreciate, if someone could tell me a function or a example code of how I can realize my idea with the AF motor shield v2.3.
Greetz
RolloBeach
Re: Move Stepper to certain positions
by adafruit_support_bill on Mon Jul 15, 2019 7:28 am
The stepper motor has no feedback, so there is no way for it to know where it is - You need to start from a known position and track the number of steps in your code.
You will need to add code and/or a limit switch for homing the motor at startup. The AccelStepper library can track the position relative to that. See the MoveTo command: https://www.airspayce.com/mikem/arduino ... 5810ec9736
Yes. There are examples included in the library.
