Move Stepper to certain positions
by RolloBeach on Mon Jul 15, 2019 7:16 am
I am using the Arduino MEGA 2560 and the AF motor shield v2.3. My goal is to define a couple of positions in my sketch and then tell the stepper to go to these positions.
Is there a way to tell stepper the next position, no matter where it actually is? I have a defined starting point, so I can create kind of a table whitch contains the steps from "point zero" to point X.
My main problem is, that I only know the simple commands like "step(200,FORWARD,SINGLE)". Is the AccelStepper library compatible to the v2.3?
I would appreciate, if someone could tell me a function or a example code of how I can realize my idea with the AF motor shield v2.3.
Greetz
RolloBeach
Re: Move Stepper to certain positions
by adafruit_support_bill on Mon Jul 15, 2019 7:28 am
The stepper motor has no feedback, so there is no way for it to know where it is - You need to start from a known position and track the number of steps in your code.
You will need to add code and/or a limit switch for homing the motor at startup. The AccelStepper library can track the position relative to that. See the MoveTo command: https://www.airspayce.com/mikem/arduino ... 5810ec9736
Yes. There are examples included in the library.
