change i2c speed on metro m4 express
by dheijl on Tue Jul 16, 2019 7:44 am
I use the Metro M4 Express to control stepper motors with Motor Shields V2, using the Arduino IDE. I like those SAMD51 boards!
But... I need to increase the i2c speed.
The recommended change in the docs is for Atmel based boards only, and I can't find the equivalent for the SAMD51 boards (I don't want to change the SAMD51 twi code).
So, I would need the SAMD51 equivalent of:
TWBR = ((CPU_FREQ / 400000L) - 16) / 2;
dheijl
Re: change i2c speed on metro m4 express
by dheijl on Tue Jul 16, 2019 9:01 am
To answer my own question: after looking at the library source code I noticed that the i2c used by the M4 Metro is Wire.
So the following line does the trick to get a higher RPM out of the steppers:
Wire.setSpeed(400000);
dheijl
by dheijl on Tue Jul 16, 2019 12:09 pm
The motor shield also support "fast plus" i2c speed (1000000) because the PCA9685 chip does.
dheijl
