Controlling Stepper Motor with Arduino Serial Monitor
by hyunterx on Mon Aug 19, 2019 12:50 pm
Hi there, I am looking to control my stepper motor's speed with arduino's serial monitor, I am using UNO and Adafruit Motor Shield V2.3
There are 4 speed divided into 4 categories a, b, c and d, the idea is that when you press 'a' the stepper motor would rotate on the selected RPM, 'b' another RPM and so-on. Press 's' and motor would stop
Everything is fine when i press 'a'. However when I want to change to 'b' there isnt any response from the motor and it will continue rotating in 'a' setting.
Attached is my code for the above scenario. Please advice
Thank you
#include <Wire.h>
#include <Adafruit_MotorShield.h>
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_StepperMotor *myMotor = AFMS.getStepper(200, 2);
  Serial.begin(9600);
  Serial.println("Stepper Test");
  AFMS.begin();
  //AFMS.begin(1000);
  char n;
  if (Serial.available() > 0)
      int command = Serial.read();
   if (command == 'a')
    Serial.println("Setting Speed to 19.1 RPM");
    delay (1000);
      do
        myMotor->setSpeed(19.1);
         myMotor->step(10000,FORWARD, DOUBLE);
      } while (Serial.available() == 0);
      Serial.read();
   else if (command == 'b')
       Serial.println("Setting Speed to 38.2 RPM");
    delay (1000);
        myMotor->setSpeed(38.2);
   else if (command == 'c')
    Serial.println("Setting Speed to 57.3 RPM");
    delay (1000);
    myMotor->setSpeed(57.3);
   else if (command == 'd')
    Serial.println("Setting Speed to 76.4 RPM");
    delay (1000);
     myMotor->setSpeed(76.4);
 else if (command == 's')
    myMotor->release();
hyunterx
Re: Controlling Stepper Motor with Arduino Serial Monitor
by adafruit_support_bill on Mon Aug 19, 2019 1:11 pm
The "step" function is a blocking function. So it will not return until after the motor has completed the 10000 steps. If you want to remain responsive to serial input, you need to take one step at a time and monitor the serial input. The AccelStepper library is the easiest way to do that. There is a link to it here: https://learn.adafruit.com/adafruit-mot ... or-arduino
by hyunterx on Mon Aug 19, 2019 1:23 pm
Essentially i want the motor to keep rotating until I input another setting. Using AccelStepper would mean that I would have to wrap the functiomn? May I ask what is wrap?
hyunterx
by adafruit_support_bill on Mon Aug 19, 2019 1:39 pm
Have a look the AccelStepper examples that come with the motor shield library. They include the necessary wrapper code.
