Motor Shield, Contolling one motor DC with three buttons
by pixeltx on Mon Sep 02, 2019 6:08 pm
I'm trying something that seems simple but my code is missing something, I have a motor shield V2 connected to a DC motor and have three buttons that I would like to use to drive the motor , button 1 run forward, button 2, run backward and button 3 stop. When I upload the sketch the motor start running as if the buttons were pressed (HIGH) even they are not, what am I missing in my code?, The buttons are wired with a pull down resistor. The Serial monitor prints Tick, Tack, Tock, even though I'm not pressing any buttons. I will appreciate any feedback.
#include <Wire.h>
#include <Adafruit_MotorShield.h>
// Create the motor shield object with the default I2C address
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
// Or, create it with a different I2C address (say for stacking)
// Adafruit_MotorShield AFMS = Adafruit_MotorShield(0x61);
// Select which 'port' M1, M2, M3 or M4. In this case, M1
Adafruit_DCMotor *myMotor = AFMS.getMotor(1);
// You can also make another motor on port M2
//Adafruit_DCMotor *myOtherMotor = AFMS.getMotor(2);
const int button1Pin = 2;  // pushbutton 1 pin
const int button2Pin = 3;  // pushbutton 2 pin
const int button3Pin = 5;  // pushbutton 3 pin
  Serial.begin(9600);           // set up Serial library at 9600 bps
  pinMode(button1Pin, INPUT);
  pinMode(button2Pin, INPUT);
  pinMode(button3Pin, INPUT);
  Serial.println("Adafruit Motorshield v2 - DC Motor test!");
  AFMS.begin();  // create with the default frequency 1.6KHz
  //AFMS.begin(1000);  // OR with a different frequency, say 1KHz
  // Set the speed to start, from 0 (off) to 255 (max speed)
  myMotor->setSpeed(200);
  myMotor->run(FORWARD);
  // turn on motor
  myMotor->run(RELEASE);
  uint8_t i;
   int button1State, button2State, button3State;  // variables to hold the pushbutton states
   button1State = digitalRead(button1Pin);
   button2State = digitalRead(button2Pin);
   button3State = digitalRead(button3Pin);
   if (button1State == HIGH);
   Serial.print("tick");
    myMotor->setSpeed(250);
    delay(1000);
  if (button2State == HIGH);
  Serial.print("tock");
  myMotor->run(BACKWARD);
    delay(1000);
 if (button3State == HIGH);
 Serial.print("tack");
  delay(1000);
Last edited by adafruit_support_bill on Mon Sep 02, 2019 7:36 pm, edited 1 time in total.
Reason: Please use the [code] button when posting code to the forums.
pixeltx
Re: Motor Shield, Contolling one motor DC with three buttons
by adafruit_support_bill on Mon Sep 02, 2019 7:37 pm
How are the buttons wired? Do you have pulldown resistors?
by pixeltx on Mon Sep 02, 2019 8:19 pm
Yes, the buttons have a pull down resistor, one each per button, button 1 is connected to pin 2, button 2 is connected to pin 3 and button 3 is connected to pin 5 (I understand pin 4 is used by the shield to drive the DC motor)
pixeltx
by adafruit_support_bill on Tue Sep 03, 2019 5:48 am
Are you talking about analog pins or digital pins?
If you are using an Arduino UNO, analog pin 4 is the SDA pin and is used to communicate with the shield. All of the digital pins are available for switches. Your code is written to use digital pins.
by pixeltx on Tue Sep 03, 2019 8:11 am
I'm using the digital pins. Am I missing to declare the status of the pins at start, like declare them LOW? Thank you!
pixeltx
by kcl1s on Tue Sep 03, 2019 8:39 am
That shows your pins are reading high. I think a photo of your wiring will help clear this up.
Fellow hobbyist
Keith
kcl1s
