Adafruit 2.7" Tri-Color eInk / ePaper Shield with SRAM - Red
- David0111
I have the Adafruit 2.7" Tri-Color eInk / ePaper Shield with SRAM - Red Black White display. Can I use it with my eps32 feather huazzh? If so how do I connect it? Thanks
- dastels
Re: Adafruit 2.7" Tri-Color eInk / ePaper Shield with SRAM -
As detailed in the tutorial: https://learn.adafruit.com/adafruit-ein ... ld-pinouts you will need to connect the 3 SPI bus connections as well as 4 digital outputs for the various select/control signals.
- David0111
I still don't understand wich pin does wich. The picture does not state what pin is what.
- dastels
SCK, MISO, and MOSI just get connected directly between the feather and the shield.
D10, D9, D8, D5 on the shield need to connect to 4 GPIO lines on the feather. The ESP32 feather doesn't have pins labeled D10, D9, D8, D5 so you'll need to select 4 that are not being used and adjust the code accordingly to pass those pins to the Adafruit_IL0373 constructor.
