Adafruit MAX31865 RTD PT100 Low Threshold
by AarronY on Thu Jun 04, 2020 11:27 am
Hey all,
I've recently purchased an Adafruit MAX31865 RTD PT100 breakout board for use with a Prosense PT100 3-wire RTD sensor (https://cdn.automationdirect.com/static ... bebors.pdf). I followed the guide: https://learn.adafruit.com/adafruit-max ... ing-config, specfically cutting the trace between 4 and 2 pads on the left of the board, as well as soldering together the 2/3 pad on the right but I get a Low Threshold Fault when running the example sketch with the MAX31865 library. Not sure how to diagnose problems or what this even means. Any help is appreciated.
RTD value: 0
Ratio = 0.00000000
Resistance = 0.00000000
Temperature = -242.02
Fault 0x40
RTD Low Threshold
AarronY
Re: Adafruit MAX31865 RTD PT100 Low Threshold
by AarronY on Thu Jun 04, 2020 11:39 am
I should also mention that I've tried two separate sensors, both the same model.
AarronY
by mikeysklar on Thu Jun 04, 2020 12:47 pm
Hi AarronY,
It sounds like you have the cut trace and solder points correct. Can you post a picture of your wiring and code modification.
mikeysklar
by AarronY on Thu Jun 04, 2020 1:39 pm
Thanks for the quick response....
This is the code that I'm using from the max31865 library. I've made no changes to it.
  This is a library for the Adafruit PT100/P1000 RTD Sensor w/MAX31865
  Designed specifically to work with the Adafruit RTD Sensor
  ----> https://www.adafruit.com/products/3328
  This sensor uses SPI to communicate, 4 pins are required to
  interface
  products from Adafruit!
  BSD license, all text above must be included in any redistribution
#include <Adafruit_MAX31865.h>
// Use software SPI: CS, DI, DO, CLK
Adafruit_MAX31865 thermo = Adafruit_MAX31865(10, 11, 12, 13);
// use hardware SPI, just pass in the CS pin
//Adafruit_MAX31865 thermo = Adafruit_MAX31865(10);
// The value of the Rref resistor. Use 430.0 for PT100 and 4300.0 for PT1000
#define RREF      430.0
// The 'nominal' 0-degrees-C resistance of the sensor
// 100.0 for PT100, 1000.0 for PT1000
#define RNOMINAL  100.0
  Serial.begin(115200);
  Serial.println("Adafruit MAX31865 PT100 Sensor Test!");
  thermo.begin(MAX31865_3WIRE);  // set to 2WIRE or 4WIRE as necessary
  uint16_t rtd = thermo.readRTD();
  Serial.print("RTD value: "); Serial.println(rtd);
  float ratio = rtd;
  ratio /= 32768;
  Serial.print("Ratio = "); Serial.println(ratio,8);
  Serial.print("Resistance = "); Serial.println(RREF*ratio,8);
  Serial.print("Temperature = "); Serial.println(thermo.temperature(RNOMINAL, RREF));
  // Check and print any faults
  uint8_t fault = thermo.readFault();
  if (fault) {
    Serial.print("Fault 0x"); Serial.println(fault, HEX);
    if (fault & MAX31865_FAULT_HIGHTHRESH) {
      Serial.println("RTD High Threshold");
    if (fault & MAX31865_FAULT_LOWTHRESH) {
      Serial.println("RTD Low Threshold");
    if (fault & MAX31865_FAULT_REFINLOW) {
      Serial.println("REFIN- > 0.85 x Bias");
    if (fault & MAX31865_FAULT_REFINHIGH) {
      Serial.println("REFIN- < 0.85 x Bias - FORCE- open");
    if (fault & MAX31865_FAULT_RTDINLOW) {
      Serial.println("RTDIN- < 0.85 x Bias - FORCE- open");
    if (fault & MAX31865_FAULT_OVUV) {
      Serial.println("Under/Over voltage");
    thermo.clearFault();
  Serial.println();
  delay(1000);
These are some pictures of the circuit (cropped)
Are there any troubleshooting steps that I can attempt?
AarronY
by mikeysklar on Thu Jun 04, 2020 2:41 pm
Hey Aaron,
You wiring looks good between the max31865 and the your Arduino board. Also the code does not need modification for the PT100 RTD you are using so the stock example is correct with the pin number and RREF value of 430. The code page suggests that the low threshold you are seeing is due to our own code not having thresholds built in at this time. I suspect it could be that the PT100 is not fully connected to the max31865. I can't confirm the terminal block connections between the max and your PT100 from the photos could you provide those as well?
mikeysklar
by AarronY on Thu Jun 04, 2020 3:14 pm
No problem. Here are the pictures:
Are there any other libraries that I should be looking into?
AarronY
by mikeysklar on Mon Jun 08, 2020 10:52 pm
Since the hardware hookup all look good. I would try the latest release of the max31865 library from github.
https://github.com/adafruit/Adafruit_MAX31865
mikeysklar
by AarronY on Tue Jun 09, 2020 10:39 am
I've just tried with the newest library and I'm still running into the same issue. Is there any possible way to set the threshold through the library or a series of SPI commands? Please advise.
AarronY
by AarronY on Wed Jun 10, 2020 11:10 am
So I dug around the code a bit and I've managed to set the threshold register to zero and still no luck. I've noticed that the reading is 0 ohms when set to 3-wire mode. I think that I may have been shipped a bad board.
AarronY
by mikeysklar on Thu Jun 11, 2020 12:15 pm
AArronY,
You had mentioned you were recently shipped this MAX board. What was the date of purchase?
mikeysklar
by AarronY on Thu Jun 11, 2020 12:18 pm
Early last week.
AarronY
by mikeysklar on Thu Jun 11, 2020 4:51 pm
AarronY,
Go ahead and write to support@adafruit.com point them at this forum thread and give them your order# so they can send you a replacement.
mikeysklar
by AarronY on Thu Jun 11, 2020 4:55 pm
Sounds good. Thank you for your help. I'll let you know what happens.
AarronY
