Pin Lyout on Proto-Screwshield R3
by DanBobber on Sun Jun 21, 2020 1:56 pm
The board shows two rows of connected points of both sides of the board (see attached) with silk screen labels "5V" and GND".
Are these rows actually connected to the UNO, for example, 5V and GND pins? I'd like to use the rows for external isolated power rails.
Thanks.
Pre Screw ShieldXX.JPG (66.5 KiB) Viewed 37 times
DanBobber
Re: Pin Lyout on Proto-Screwshield R3
by adafruit_support_bill on Mon Jun 22, 2020 5:11 am
Yes. These are connected to the +5 and GND rails on the UNO. But it would not be difficult to cut the traces leading to those pins to isolate the rails.
by DanBobber on Mon Jun 22, 2020 10:08 am
Cutting traces....exactly what I had thought. But didn't know if the board was 2 or 4 layers. Figured if 2 layer one could probably cut a couple traces.
Thanks for the info.
DanBobber
by adafruit_support_bill on Mon Jun 22, 2020 10:11 am
It is a 2-layer board. You should not have difficulty identifying the traces from either the top of bottom side of the board.
