Arduino MEGA & 2.8 TFT LCD Shield
by MadsNi on Mon Jul 06, 2020 12:40 pm
Hi, I'm learning how to use the shield. It seems like its easy to use with an UNO-Board but not quite as easy to use with a MEGA board, as said in this guide: https://learn.adafruit.com/adafruit-2-8 ... connecting
I got the graphics to work on the MEGA by using the ICSP instead of pin 13, 12 and 11 (as the instructions showed on the shield - See Image 1)
Image 1 - (shield backside)
Anmærkning 2020-07-06 182838.png (344.46 KiB) Viewed 30 times
I did the graphics "benchmark-test" and it worked fine. But i can't get the touch to work. I followed the instructions in this link: https://learn.adafruit.com/adafruit-2-8 ... paint-demo
But my code wound't compile, with the error message: 'STMPE_CS' was not declared in this scope
I tried the example, but i said the same, just in the Serial monitor - See image 2
Image 2 - (Code Error)
What is causing this issue? Hope you can help - thanks in advance
MadsNi
Re: Arduino MEGA & 2.8 TFT LCD Shield
by indy on Wed Jul 08, 2020 3:05 pm
In the link you included they refer to the touch shield only requiring one additional pin, #8. In the code, try replacing 'STMPE_CS' with 8 and see if it works.
Hope that helps.
indy
