Ultimate GPS with USB - Works on Windows not in Debian
by d_sas on Mon Jul 06, 2020 2:51 pm
I'm trying to get an ultimate GPS with USB working in a debian 6.0.6 (running kernel 2.6.32). When I connect the unit up to my laptop USB (running windows 10) I can see the NMEA sentences in a terminal program (Putty or Teraterm). When I connect to the USB port on the Debian box, I can see the USB device populate in dmesg as shown below, but the output doesn't appear when I "cat /dev/ttyUSB1" .
On the board, I can see the tx and rx LEDs flashing when I run the cat/dev/ttyUSB1 command so I think the board is communicating at some level but I don't see any readable sentences. I've got two separate Ultimate GPS boards and both are behaving the same. I'm guessing it's a driver issue, but the cp210x.ko and usbserial drivers are both loaded in debian.
Any ideas on how to troubleshoot?
Output of dmesg:
[ 1068.468724] usb 3-2: new full speed USB device using ohci_hcd and address 4
[ 1068.699881] usb 3-2: New USB device found, idVendor=10c4, idProduct=ea60
[ 1068.699919] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1068.699946] usb 3-2: Product: CP2104 USB to UART Bridge Controller
[ 1068.699968] usb 3-2: Manufacturer: Silicon Labs
[ 1068.699988] usb 3-2: SerialNumber: 01C72D75
[ 1068.708715] usb 3-2: configuration #1 chosen from 1 choice
[ 1068.713918] cp210x 3-2:1.0: cp210x converter detected
[ 1068.888802] usb 3-2: reset full speed USB device using ohci_hcd and address 4
[ 1069.102459] usb 3-2: cp210x converter now attached to ttyUSB1
d_sas
Re: Ultimate GPS with USB - Works on Windows not in Debian
by dherrada on Mon Jul 06, 2020 5:04 pm
Have you tried connecting with screen instead?
dherrada
by d_sas on Mon Jul 06, 2020 5:13 pm
I have unfortunately screen doesn't appear to be a valid command on this system:
root@hostname:/dev#screen /dev/ttyUSB1
-bash: screen: command not found
d_sas
by dherrada on Mon Jul 06, 2020 5:15 pm
You could try installing it with apt. tmux is also something people use, but I've never tried it out.
dherrada
