Strange Stepper Speeds
by royBattyJr on Sun Jul 12, 2020 8:41 pm
I'm using a NEMA-17 stepper (product 324) with a motor shield v2 (1438) and an Arduino Uno. I've experimented with a lot of different code, but this is the most basic version of what I'm running:
#include <Wire.h>
#include <Adafruit_MotorShield.h>
Adafruit_MotorShield AFMS = Adafruit_MotorShield(0x61);
Adafruit_StepperMotor *myMotor = AFMS.getStepper(200, 2);
  AFMS.begin(9000);
  myMotor->setSpeed(18); //different results for the "setSpeed" value are listed later in this post
  myMotor->step(200, BACKWARD, DOUBLE);
The problem I'm having is that each RPM setting has a corresponding actual RPM output:
code RPMs - actual RPMs
1 - 34
2 - 48
3 - 55
4 - 23
5 - 21
6 - 66
7 - 23
8 - 37
9 - 71
10 - 18
11 - 21
12 - 26
13 - 30
14 - 35
15 - 42
16 - 55
17 - 60
18 - 74
All speeds above 18 are slower than 74 RPMs. There's no missed steps or slipping even with a load on it. If it were a clock speed problem, I would expect it to still ascend in speed rather than peaking at certain settings. I have multiple motor shields, steppers, power supplies, and arduinos I've tried it on so I don't think it's faulty hardware. Updating the libraries didn't make a difference. I'm out of ideas for things to try and figured it's time to ask for help. Mostly I'm looking for an explanation for why the speeds are weird. The weird speeds aren't a problem by themselves, but if whatever I'm doing wrong is preventing higher speeds, I'd like access to them.
royBattyJr
Re: Strange Stepper Speeds
by adafruit_support_bill on Sun Jul 12, 2020 8:53 pm
The motor speed settings in the library are not very precise. The step rate calculations do not take into account the software or communications overhead. For more accurate timing, it is best to use millis() timing and OneStep, or the AccelStepper library.
There is also an upper limit imposed by the speed of the i2c bus. This is discussed in detail here: viewtopic.php?f=31&t=57041&p=292119
