MAX31865 module not measuring properly
by angel6700 on Wed Jul 15, 2020 2:59 pm
I have recently bought a MAX31865 module (original adafruit), bought from digikey.
I'm trying to use with a miniature PT100 .
I initially connected everything (4-wires)) loaded the example provided in with your library, but after a few readings it starts giving wrong results. Like -200 Ohm resistance (at room temperature).
Now, even the start is wrong. Even connecting a 100 Ohm resistor in place a sensor the behavior is the same.
I double checked the wiring, the sensor wiring and all seems fine. You can see in the pictures:
Any Idea what can be wrong?
Thanks in advance.
angel6700
Re: MAX31865 module not measuring properly
by angel6700 on Thu Jul 16, 2020 4:34 am
I forgot to add the output in the serial Monitor:
First, the code (plain example unmodified (only the line concerning the 4-wire connection)
X axis is time in seconds.
Y axis is temperature in Celsius
Max31865_PT100_serial plotter.png (37.34 KiB) Viewed 24 times
Thank you.
angel6700
