PowerBoost Shield 500
by Crentist on Mon Jul 20, 2020 12:25 pm
Hi support, I purchased the PowerBoost 500 shield last week (order no.2323676-2625846677) and I'm having issues with getting the battery to power my Arduino (battery also purchased at the same time: Lithium Ion Battery - 3.7v 2000mAh).
No matter what I try, the charge controller seems to be blocking the circuit, I heard there's a fuse on the board somewhere that can trip to protect the battery but I'm unsure which component it is on the board, if someone can clearly identify it for me I'll gladly test it for continuity with my multimeter.
Photo album of troubleshooting steps here: https://imgur.com/a/4MOvYw9
Crentist
Re: PowerBoost Shield 500
by adafruit_support_bill on Mon Jul 20, 2020 12:38 pm
Please post photos showing your soldering to the shield.
by Crentist on Mon Jul 20, 2020 1:33 pm
I updated the album with view of header pins, my soldering isn't the best but nothing appears to be bridged and multimeter tests that bypass charge controller show they do complete a circuit. https://imgur.com/a/4MOvYw9
Crentist
by Crentist on Mon Jul 20, 2020 1:40 pm
Might be worth mentioning that when I first plug in the battery I do get a quick flash from the LED and then everything dies.
Crentist
by adafruit_support_bill on Mon Jul 20, 2020 1:57 pm
If you remove the shield from the Arduino and connect both the battery and USB, which LEDs on the shield light up?
by Crentist on Mon Jul 20, 2020 2:24 pm
Only the yellow charge light.
Crentist
by adafruit_support_bill on Mon Jul 20, 2020 2:26 pm
Sounds like the boost section is not working for some reason. With no switch installed, it should default to ON as long as there is a battery connected.
Did you purchase this direct from Adafruit, or from a reseller?
by Crentist on Mon Jul 20, 2020 2:27 pm
Direct from adafruit last week, order # in first post.
Crentist
by adafruit_support_bill on Mon Jul 20, 2020 2:59 pm
OK. Please contact support@adafruit.com with a link to this thread and request a replacement shield.
by Crentist on Fri Jul 24, 2020 12:11 pm
My new shield came in and I've integrated it into the project, it worked until this morning and now something seems wrong with it.
When the arduino is hooked up direct to the computer and the powerboost shield is installed I need to flip the shield's switch in order for things to work properly, otherwise my output of my attached accelerometer is garbage or non-existent.
Then if I disconnect the arduino's usb cable I'd expect the device to keep receiving power from the shield + 2000mAh batter but the lights on the arduino go off or dim greatly. It's as if the lipo battery isn't sending enough power to the arduino.
Can you suggest some thing I can check? It was all working last night and the battery is fully charged (green light on shield). Even with the arduino appearing dead, I can detect 5v going through my breadboard.
https://imgur.com/a/rpICa1k
Crentist
by adafruit_support_bill on Fri Jul 24, 2020 1:57 pm
With the battery unplugged, what is the voltage across the battery leads?
With the shield detached from the circuit, do you get a solid 5v on the 5v pin?
by Crentist on Fri Jul 24, 2020 2:42 pm
With arduino on USB and battery unplugged 0.830v (shield not connected to charge cable) measured on the GND & 5v pin on shield.
Crentist
by Crentist on Fri Jul 24, 2020 2:45 pm
Without shield, 5.135v on same pins. What does this mean? There's a short somewhere on the shield?
Crentist
by adafruit_support_bill on Fri Jul 24, 2020 2:59 pm
With the battery unplugged, please measure the voltage on the battery leads.
by Crentist on Fri Jul 24, 2020 3:02 pm
steady 4.186v (this is my battery FYI: https://www.adafruit.com/product/2011)
Crentist
