Wav Shield issue with WAV Files - Help
by mcclarydesign on Sun Aug 09, 2020 3:19 pm
I am working on making the Voice Changer but I am having an issue with reading the WAV files from the SD Card.
The SD card seems to be reading fine and if I run the example SDReadTest it seems to read the card just fine and here is the serial output.
init time: 21
Card type: SDHC
Manufacturer ID: 0
OEM ID:
Product: APPSD
Version: 0.0
Serial number: 117473298
Manufacturing date: 4/2020
card size: 7864320 (512 byte blocks)
partion,boot,type,start,length
1,0,B,8192,7856128
2,0,0,0,0
3,0,0,0,0
4,0,0,0,0
Read test starting. Please Wait.
Read 20000 blocks
mills: 19571
Done
type any character to start
When I run the adavoice code the voice changer works, but it doesn't play the startup.wav or any of the sample wav files. This is the output of the serial.
Files found:
BREATH.WAV
BURP.WAV
CARHORN.WAV
CRUNCH.WAV
DESTROY.WAV
DOOR.WAV
FOGHORN.WAV
HITHERE.WAV
SABER.WAV
SMELL.WAV
SQUIRREL.WAV
STARTUP.WAV
ZILLA.WAV
SYSTEM~1/
File: startup.wav
DVOLUME must be set to non-zero in WaveHC.h
Not a valid WAV
Pitch: 611
I have tried the other examples like PiSpeakHC and I am getting the same error "DVOLUME must be set to non-zero in WaveHC.h
Not a valid WAV"
Also note that the SD card was formated with the official SD card format utility. I also when through and have checked all the soldering and it all looks good.
Kind of stuck at this point. Can anyone help?
mcclarydesign
