Adafruit 16-channel PWM/Servo Shield vs Stepper Motor/Servo
by BPerry on Mon Aug 10, 2020 6:02 pm
I had previously used a Stepper motor/servo shield and programmed my two servos with ease using servo.attach(90) type commands. With your Adafruit 16-channel PWM/Servo Shield it seems to require using pwm.setPWM(servonum, 0, pulselen) type statements which I am having difficulty with. All I need to do is move 6 servos from 0 to 90 degrees together. I can't seem to figure out how to do this using this shield. I was using your Adafruit PWM Servo Driver Library>Servo example code to get started. Any help would be greatly appreciated!
Bob
BPerry
Re: Adafruit 16-channel PWM/Servo Shield vs Stepper Motor/Se
by adafruit_support_bill on Mon Aug 10, 2020 7:05 pm
Start with the example code from the library. That has default definitions for SERVOMAX and SERVOMIN. Those are good starting points for most servos, but may need to be tweaked a bit for best accuracy.
To move a servo to 0 degrees:
pwm.setPWM(servonum, 0, SERVOMIN);
To move it to 90 degrees:
pwm.setPWM(servonum, 0, (SERVOMAX - SERVOMIN) / 2);
by BPerry on Tue Aug 11, 2020 10:14 am
Thank you very much! Everything works great now.
BPerry
