AF motor shield pinout for " knob"
by OnyxWalker on Mon Oct 12, 2020 4:27 pm
Hi, I'm trying to run the KNOB file from Arduino library using the AF v.1 shield.
I connected pin 9 to the potentiometer along with 5v just like I did prior to installing the shield. I'm also using an external power source for
my servo 8.0 volts. which I connected directly to the motor shield.
The software loaded fine but I'm not getting any movement from my servo ?
I'm assuming my problem is in the wiring so If anyone would happen to have a pinout or wire diagram that would be greatly appreciated,
Thanks.
OnyxWalker
Re: AF motor shield pinout for " knob"
by adafruit_support_bill on Mon Oct 12, 2020 5:02 pm
Please post photos showing your soldering and connections.
Also please post the exact code you are using.
by OnyxWalker on Mon Oct 12, 2020 5:48 pm
knob-AF.ino
(972 Bytes) Downloaded 6 times
sorry my pull downs are acting weird.
OnyxWalker
by adafruit_support_bill on Mon Oct 12, 2020 6:36 pm
Your sketch does not use the shield. So there should not be any conflict.
