Run stepper on button press stop working
by Techguy817 on Wed Oct 21, 2020 10:06 pm
Hi all,
Working on a relatively simple project with my Leonardo and the motor shield. When pressing the momentary button I'd like to run the stepper a short turn. This actually appears to work for a small random amount of times (maybe 2-5) but then it stops until I do a reset.
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include <Adafruit_PWMServoDriver.h>
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_StepperMotor *myMotor = AFMS.getStepper(200, 2);
int buttonState = 0;        // initialize button to 0
  pinMode(2, INPUT);        // input pin for button
  AFMS.begin();             // intialize motor shield
  myMotor->setSpeed(100);   // set RPM
  myMotor->step (100, FORWARD, SINGLE);   // do initial step on start-up
    buttonState = digitalRead(2);
    if(buttonState == LOW) //button pressed
      digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
    myMotor->step (30, FORWARD, DOUBLE);
Any ideas?
Techguy817
Re: Run stepper on button press stop working
by franklin97355 on Wed Oct 21, 2020 11:54 pm
What is the resistance per phase on the stepper and how long do you wait per button push?
franklin97355
by Techguy817 on Thu Oct 22, 2020 8:00 am
I'm using the motor at https://www.adafruit.com/product/324. I wait a few seconds between button presses.
Techguy817
by adafruit_support_bill on Thu Oct 22, 2020 8:55 am
Please post some photos showing your soldering and connections.
Unless you have an external pullup resistor on your button, you need to enable the input one in your pinMode statement: https://www.arduino.cc/reference/en/lan ... o/pinmode/
 pinMode(2, INPUT_PULLUP);        // input pin for button
by Techguy817 on Thu Oct 22, 2020 9:19 am
Here are some photos. I tried using the Fritzing tool to create a schematic diagram but I didn't find the Adafruit motorshield in there.
Techguy817
by adafruit_support_bill on Thu Oct 22, 2020 9:32 am
What are you using to power the motor? Does the green power led on the shield remain on even when the motor does not run?
by Techguy817 on Thu Oct 22, 2020 9:33 am
The green LED on the motor shield remains on. I'm using a 12V power source wired up.
Techguy817
by adafruit_support_bill on Thu Oct 22, 2020 9:48 am
Volts is not power. You need amps too. https://www.engineeringclicks.com/watts ... -ohms-law/
What 12v supply are you using to power your motor?
I'd add a Serial.println() statement in your loop to print the buttonState and verify that it is changing as expected when pressing the button.
by Techguy817 on Thu Oct 22, 2020 10:04 am
Supply is rated at 5 amp output.
Techguy817
by Techguy817 on Thu Oct 22, 2020 2:56 pm
In looking into this further, it seems to be some kind of blocking issue with the stepper code/libraries. Using the momentary button to trigger an LED works fine continuously.
Any suggestions for tweaking my code?
Techguy817
by adafruit_support_bill on Thu Oct 22, 2020 3:47 pm
Did you add the serial debugging output as suggested? Does the output change every time you press the button?
by Techguy817 on Thu Oct 22, 2020 4:03 pm
I have not. Can you please point me to the details on serial debugging and I'll get that enabled?
Techguy817
by adafruit_support_bill on Thu Oct 22, 2020 4:07 pm
by Techguy817 on Thu Oct 22, 2020 4:41 pm
Thanks. I configured the serial debugging and it outputs 1 until the button is pressed. Then it outputs 0 a couple of times depending how long its pressed. When the board locks up it just freezes and no more serial output. E.g.
1
1
1
1
1
1
1
1
1
1
1
1
1
1
Techguy817
by adafruit_support_bill on Thu Oct 22, 2020 6:07 pm
Sounds like probably a marginal connection on the i2c bus. Please post some photos showing your soldering to the shield.
