RTC clock issue
RTC clock issue
by conroyw on Sun Nov 08, 2020 2:47 pm
I have the Rev B cataloger shield with the Real Time Clock. The demo program for the SD card works fine. The demo program for the RTC doesn't work at all. I see the program loading up but no response from the board. I have the following configuration:
Arduino IDE 1.8.13 on a Mac running OS 10.15.7
Sketch name: pcf8523
I made no changes to the sketch.
Adafruit Metro board
Any suggestions?
conroyw
Re: RTC clock issue
by mikeysklar on Mon Nov 09, 2020 9:26 pm
@conroyw,
When you open the serial console at the default baudrate (57,600) do you see anything?
Can you post a photo of your wiring to the Metro.
It is not a Metro M0, correct? The wiring would be different if you had an M0 version of the Metro.
mikeysklar
Re: RTC clock issue
by conroyw on Tue Nov 10, 2020 3:10 pm
Thanks, I found issue. I had a bad usb cable. Different cable and it works fine.
conroyw
