mechanical information for HMC5883L
by ron2k19 on Mon Nov 23, 2020 10:29 pm
Hi there,
Is there someone who can help us to identify the missing dimensions/references for this part? HMC5883L (See screenshot) Thanks![img][img][/img][/img]
ron2k19
Re: mechanical information for HMC5883L
by millercommamatt on Tue Nov 24, 2020 5:07 pm
0.1 inches between the centers of the small pin holes. That's a standard size.
millercommamatt
by ron2k19 on Wed Feb 17, 2021 4:07 am
I see but I still need the height and dimensions of the header strips. (See screenshots)
imagen (1).png (107.58 KiB) Viewed 76 times
ron2k19
by millercommamatt on Wed Feb 17, 2021 2:53 pm
The pins are typically 0.025" square. The typical pitch is 0.1". All dimensions can be ordered to spec.
In the case of the header you've taken a picture of, the insulator is 0.1" in height and depth. The pins slide in the insulator so your y1 dimension is variable. In the case of your picture, the pin extends 0.25" above the insulation and 0.12" below.
The overall pin length is 0.47".
Again, you can order pin headers just about anyway you want them.
millercommamatt
