Hi. My Adafruit Data Logger Shield RTC drifts backwards after taking the correct time from my pc. After about 3 minutes of not advancing it settles down to a time about 8 minutes earlier that the time it started running. Has anyone ever heard of this and is there a solution? I've been playing with this code for calibrating through the Arduino Example from the RTClib > pcf8523 with no success. Thanks for any help.
float drift = -64; // seconds plus or minus over oservation period - set to 0 to cancel previous calibration.
float period_sec = (7 * 86400); // total obsevation period in seconds (86400 = seconds in 1 day: 7 days = (7 * 86400) seconds )
float deviation_ppm = (drift / period_sec * 1000000); // deviation in parts per million (μs)
//float drift_unit = 4.34; // use with offset mode PCF8523_TwoHours
float drift_unit = 4.069; //For corrections every min the drift_unit is 4.069 ppm (use with offset mode PCF8523_OneMinute)
int offset = round(deviation_ppm / drift_unit);
//rtc.calibrate(PCF8523_TwoHours, offset); // Un-comment to perform calibration once drift (seconds) and observation period (seconds) are correct
//rtc.calibrate(PCF8523_TwoHours, 0); // Un-comment to cancel previous calibration
rtc.calibrate(PCF8523_OneMinute, offset);
Serial.print("Offset is "); Serial.println(offset); // Print to control offset
Arduino Data Logger Shield RTC Drifts Backwards
- JackInz
- tuttles_mower
Re: Arduino Data Logger Shield RTC Drifts Backwards
Ive had wonky things very similar to this. I found the problem to go away if I reloaded the sketch. sometimes its helpful to hold your breath while standing on your left foot.
