How to make linear actuator
Re: How to make linear actuator
by adafruit_support_bill on Sun Mar 07, 2021 7:08 am
You cannot power those from the Arduino, You will need a power supply capable of supplying 2 amps at least.
by fpthomas on Sun Mar 07, 2021 11:41 am
Bill - what does such a power supply look like and how do I wire it? I couldn't find an example.
fpthomas
by adafruit_support_bill on Sun Mar 07, 2021 12:33 pm
This 5v @ 2A supply should work with that motor: https://www.adafruit.com/product/276
For better performance, you can use a higher voltage supply like this one: https://www.amazon.com/NorthPada-Portab ... r_1_1_sspa
The maximum voltage the board will handle is 10.8v, so do not use a power supply with a voltage any higher than that.
In either case you would wire this to the "VMOTOR" terminals on the end of the board. https://learn.adafruit.com/adafruit-drv ... -2224620-2
The barrel plug from the power supply will plug into an adapter like this. Then you can run wires from the screw terminals to the DRV8833 board.
https://www.adafruit.com/product/368
Do pay attention to the polarity. Connecting + to - and - to + will damage the board.
by fpthomas on Thu Mar 25, 2021 8:18 pm
Bill. Where do I connect the negative wires for the power supply. I’ve tried both the - at the end of the motor driver board and the gnd on the board accessible through the breadboard. I think it’s the gnd. Because once I started fiddling with the connector is I got some movement. But it’s stops and starts which feels like a connection issue. Is there any way to determine which of the four wires from the motor should be paired together on the a and b outputs from the driver board? Thank. So close! Parker.
fpthomas
by fpthomas on Thu Mar 25, 2021 9:10 pm
Bill - I soldered the wires together to get a solid connection between the motor wires and the driver board (through the breadboard). the motor moves, but its really twitchy and not strong at all. Any suggestions?
fpthomas
by adafruit_support_bill on Fri Mar 26, 2021 6:24 am
Some of those solder joints do not appear to have flowed well onto the solder pads.
See this guide for some tips on identifying and fixing common soldering problems:
https://learn.adafruit.com/adafruit-gui ... n-problems
