How to make linear actuator
by fpthomas on Sun Jan 10, 2021 5:47 pm
Hi there. Has anyone created a linear actuator with a stepper motor? Any suggestions?
I can't find one on Ada fruit, but this looks like something very similar https://www.amazon.com/gp/product/B07T7 ... 894a8&th=1
It looks like a similar Nema 17 motor. how can I figure out if the Adafruit motor shield would run it?
Thanks. Parker
fpthomas
Re: How to make linear actuator
by dastels on Sun Jan 10, 2021 6:06 pm
It depends on what you want to do with the linear motion. A worm and a threaded collar, i.e. a leadscrew https://en.wikipedia.org/wiki/Leadscrew (as you show and as is used in many 3d printers) is one approach. Another is a rack and pinion style https://en.wikipedia.org/wiki/Rack_and_pinion. Small (and low power) rack & pinion actuators are pretty easy to print.
Adafruit has a NEMA-17 size stepper that will work with the shield. The shield can handle 1.2A per channel, so as long as the stepper coils aren't ratted at more current than that, should be ok.
For details see https://learn.adafruit.com/all-about-stepper-motors/matching-the-driver-to-the-stepper.
dastels
by fpthomas on Mon Jan 11, 2021 1:49 am
Dastels - thank you so much for your reply. I think that a stepper motor with the long screw makes the most sense for strength and that it's already preassembled. This one on Amazon looks like it's got 1.5 A as the rated current and a phase resistant of 1.6 ohms. I can't find something similar on Adafruit, so I will reluctantly enrich Mr. Bezos. If I'm following the article correctly, then it needs 2.4 volts?
so if the Adafruit shield can generate 1.2 amps per channel, does that mean it can drive this but torque will be reduced?
Here's the one I'm trying to power. https://www.amazon.com/gp/product/B07T7 ... 3240e894a8
Thank you.
Parker
fpthomas
by adafruit_support_bill on Mon Jan 11, 2021 7:30 am
The Amazon unit is not compatible with our shield. Motors with extremely low phase resistance are intended for use with current limiting drivers such as the DV8833.
https://www.adafruit.com/product/3297
https://learn.adafruit.com/all-about-st ... 1460534-10
by fpthomas on Mon Feb 15, 2021 10:32 pm
Might anyone be willing to help me debug a project? trying to make a linear actuator using the DRV8833 and https://www.amazon.com/gp/product/B0776 ... =UTF8&th=1
Got the code from https://learn.adafruit.com/adafruit-drv ... otor-usage and hooked everything up - nada. According to previous comment, that's the right motor driver for the motor.
it could certainly be my soldering. maybe I melted something holding 8833 to the pins on the breadboard. How can I check? looks like one outer wire and one inner wire on motor wires comprise a pair, so tried various combinations.
What else do I check?
Thanks.
fpthomas
by adafruit_support_bill on Tue Feb 16, 2021 6:46 am
We can't really make out any detail in those photos. If you can post some with better focus we can take a look.
by dastels on Tue Feb 16, 2021 10:43 am
Better focus and higher resolution, please.
dastels
by fpthomas on Tue Feb 16, 2021 12:48 pm
So sorry - here are few better pics. Thank you!
fpthomas
by fpthomas on Tue Feb 16, 2021 12:50 pm
and a few more.
fpthomas
by dastels on Tue Feb 16, 2021 12:55 pm
You definitely need to redo the soldering on the breakout. Look under the UNO to see what they should look like. See https://learn.adafruit.com/adafruit-guide-excellent-soldering and https://learn.adafruit.com/collins-lab-soldering for more information.
dastels
by adafruit_support_bill on Tue Feb 16, 2021 1:25 pm
Looks like most of the pins have enough solder. It just hasn't flowed onto the solder pads. You should be able to fix most of those by just re-heating them. Make sure that the tip of your iron is contacting the solder pad that surrounds the pin. That part needs to get hot enough so the solder can flow onto it.
The ideal cross-section of a joint should look like the diagram below:
https://learn.adafruit.com/adafruit-gui ... tep-418537
by fpthomas on Sat Mar 06, 2021 6:33 pm
Hi - everyone and thanks for all the feedback. I redid all the solders on the motor driver. Now the motor clicks occasionally but won't actually turn. Any suggestions? same behavior for both 3.3 and 5.5 power outputs on the Arduino board.
Parker
fpthomas
by fpthomas on Sat Mar 06, 2021 7:36 pm
IMG_8338 (1).jpg (299.26 KiB) Viewed 247 times
IMG_8337 (1).jpg (383.43 KiB) Viewed 247 times
IMG_8336 (1).jpg (515.04 KiB) Viewed 247 times
And a few pics
fpthomas
by adafruit_support_bill on Sat Mar 06, 2021 8:52 pm
What motor are you using?
by fpthomas on Sat Mar 06, 2021 8:58 pm
I think it is for a 3d printer. Needed a longer screw than I could find on adafruit - I'm sorry.
Parker
fpthomas
