Shield_sdlog
Shield_sdlog
by ks12 on Fri Feb 19, 2021 6:47 pm
I am trying to run the Shield_sdlog code from the ad fruit example of the latest library as of 2/19/21 on my UNO REV2 WIFI and for some reason have received this error pertraining to the ORC0A reference.
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno WiFi Rev2, ATMEGA328"
In file included from C:\Users\Kurrin\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/Arduino.h:27:0,
from sketch\shield_sdlog.ino.cpp:1:
C:\Users\Kurrin\Documents\Arduino\libraries\Adafruit_GPS_Library\examples\shield_sdlog\shield_sdlog.ino: In function 'void TIMER0_COMPA_vect()':
C:\Users\Kurrin\Documents\Arduino\libraries\Adafruit_GPS_Library\examples\shield_sdlog\shield_sdlog.ino:144:5: warning: 'TIMER0_COMPA_vect' appears to be a misspelled 'signal' handler, missing '__vector' prefix [-Wmisspelled-isr]
ISR(TIMER0_COMPA_vect) {
C:\Users\Kurrin\Documents\Arduino\libraries\Adafruit_GPS_Library\examples\shield_sdlog\shield_sdlog.ino: In function 'void useInterrupt(bool)':
shield_sdlog:159:5: error: 'OCR0A' was not declared in this scope
OCR0A = 0xAF;
C:\Users\Kurrin\Documents\Arduino\libraries\Adafruit_GPS_Library\examples\shield_sdlog\shield_sdlog.ino:159:5: note: suggested alternative: 'O_CREAT'
OCR0A = 0xAF;
O_CREAT
shield_sdlog:160:5: error: 'TIMSK0' was not declared in this scope
TIMSK0 |= _BV(OCIE0A);
C:\Users\Kurrin\Documents\Arduino\libraries\Adafruit_GPS_Library\examples\shield_sdlog\shield_sdlog.ino:160:5: note: suggested alternative: 'TIMERA0'
TIMERA0
In file included from c:\users\kurrin\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5\avr\include\avr\io.h:99:0,
from c:\users\kurrin\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5\avr\include\avr\pgmspace.h:90,
from C:\Users\Kurrin\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/String.h:31,
from C:\Users\Kurrin\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/IPAddress.h:24,
from C:\Users\Kurrin\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/ArduinoAPI.h:30,
from C:\Users\Kurrin\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/Arduino.h:23,
shield_sdlog:160:19: error: 'OCIE0A' was not declared in this scope
shield_sdlog:165:5: error: 'TIMSK0' was not declared in this scope
TIMSK0 &= ~_BV(OCIE0A);
C:\Users\Kurrin\Documents\Arduino\libraries\Adafruit_GPS_Library\examples\shield_sdlog\shield_sdlog.ino:165:5: note: suggested alternative: 'TIMERA0'
TIMERA0
shield_sdlog:165:20: error: 'OCIE0A' was not declared in this scope
exit status 1
ks12
