Feather Lora + Adalogger Featherwing
by atmosferico on Tue Feb 23, 2021 6:06 am
I am using a Feather M0 with a datalogging firewing (RTC + SD card).
I have tried many sample sketches and many libraries, I have read various formums trying different solutions
but I was unable to write and read any data on the SD card.
I tried using the example sketches, first with
an arduino ONE
and later with an arduino DUE
and everything works perfectly.
At this point, I assume there is something wrong with the libraries.
any suggestions?
Thank you
Eric
atmosferico
Re: Feather Lora + Adalogger Featherwing
by mikeysklar on Tue Feb 23, 2021 8:22 pm
Hi Eric,
I take it you had been using the Arduino libraries since you were able to switch over to UNO and DUE?
Were you able to successfully run the RTC test with the FeatherWing? That will help give us some idea if there is any communication.
https://learn.adafruit.com/adafruit-ada ... th-arduino
Is there any other devices connected to your M0 beside this wing?
mikeysklar
by jerryn on Tue Feb 23, 2021 10:37 pm
Note the warning here https://learn.adafruit.com/adafruit-feather-m0-radio-with-lora-radio-module/pinouts#rfm-slash-semtech-radio-module-2825156-12. You have to set the CS pin #8 High when using another SPI device.
jerryn
by atmosferico on Wed Feb 24, 2021 8:58 am
>Note the warning here https://learn.adafruit.com/adafruit-fea ... 2825156-12. You have to set the CS pin
#8 High (when using another SPI device).
Grazie 1000
now it works perfectly!!!
Eric
atmosferico
