Adafruit motor shield V2 motor status
by chimerical26 on Thu Mar 04, 2021 12:21 pm
Is there any way that I can check the status of the motor?
For example, after I run:
myMotor->step(150, BACKWARD, DOUBLE);
I would like to be able to know when it has completed this so that I can trigger the next step.
PS. I am controlling the arduino over usb using pyserial so timing isn't great but I feel if I could tell that the motor has stopped moving it might help. Maybe I'm wrong.
chimerical26
Re: Adafruit motor shield V2 motor status
by adafruit_support_bill on Thu Mar 04, 2021 12:26 pm
The adafruit stepper library is synchronous. The 'step' function will not return until the motor has completed all the steps.
by chimerical26 on Thu Mar 04, 2021 2:30 pm
Thank you. It must be an issue with the way I'm using pyserial then. Appreciate the response.
chimerical26
by chimerical26 on Mon Mar 15, 2021 9:00 pm
When I run what I have below I get the output I have below. I would expect an X after every Ard Read if everything is working as it should. Serial connection works fine for simple programs that don't use the Adafruit shield. Without this return telling me the motor has completed its action I have to use timing which is not what I would like. This has been tormenting me for a while now. Can you offer any advice please? Thank you.
Arduino Code:
#include <Wire.h>
#include <Adafruit_MotorShield.h>
int incomingData;
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_StepperMotor *myMotor = AFMS.getStepper(200, 2);
  Serial.begin(9600);
  AFMS.begin();
  myMotor->setSpeed(50);
  TWBR = ((F_CPU /400000l) - 16) / 2;
  while (Serial.available()) {
    incomingData = Serial.read();
    if (incomingData == '5') {
      myMotor->step(10, BACKWARD, DOUBLE);
      Serial.println('X');
Python Code:
import serial
from time import sleep
ard = serial.Serial('com3', 9600, timeout=0.5) #set up Arduino serial connection and baud rate
sleep(2)
i=0
while(i < 6):
    ard.write(b'5') #tell Arduino rotate 18 degrees
    sleep(0.5)
    i=i+1
    returned = ard.read().decode('ascii')
    print("Ard Read" + returned)
ard.close() # Close serial link with Arduino
Output:
Ard ReadX
Ard Read
Ard Read
Ard ReadX
Ard Read
Ard Read
chimerical26
by adafruit_support_bill on Tue Mar 16, 2021 5:27 am
Using println(), you should expect an 'X' followed by an ASCII CR and an LF.
https://www.arduino.cc/reference/en/lan ... l/println/
If you want jus the 'X', you should use print(): https://www.arduino.cc/reference/en/lan ... ial/print/
