Music Maker to play midi files.
by rwl7532 on Sat Mar 06, 2021 6:59 pm
I bought your Music Maker Shield for my Arduino Uno. The VS1053 datasheet on pages 44 and 86 refers to midi files. How do I play a midi file? All the Adafruit VS1053 library examples have successfully been run.
A simple sketch example should be sufficient.
rwl7532
Re: Music Maker to play midi files.
by blnkjns on Mon Mar 08, 2021 1:54 am
How did you hookup stuff? What board, what connections?
It seems you need to feed the MIDI data to the UX/TX pin, and how do you get it there? Did you set up a 32U4 based board as MIDI forwarder? It needs true MIDI stream data, not MIDI files! So you could have a computer generate USB midi from a MIDI file.
blnkjns
by rwl7532 on Mon Mar 08, 2021 9:36 am
blnkjns wrote:How did you hookup stuff? What board, what connections?
I'm anticipating a reply from Adafruit support.
rwl7532
by rwl7532 on Wed Mar 17, 2021 7:46 pm
rwl7532 wrote:I bought your Music Maker Shield for my Arduino Uno. The VS1053 datasheet on pages 44 and 86 refers to midi files. How do I play a midi file? All the Adafruit VS1053 library examples have successfully been run.
@adafruit_support_bill Has any support tech seen my post?
rwl7532
by blnkjns on Thu Mar 18, 2021 9:00 am
You can wait for that, but their documentation says MIDI streams, no MIDI files.
blnkjns
by rwl7532 on Thu Mar 18, 2021 11:04 am
blnkjns wrote:You can wait for that, but their documentation says MIDI streams, no MIDI files.
"The VS1053 datasheet on pages 44 and 86 refers to midi files."
Is the datasheet incorrect?
rwl7532
