Fram problems
Fram problems
by LeeBurrow on Wed Mar 10, 2021 3:59 am
Recently bought SPI FRAM - unfortunately although the board is recognized, for some reason I can't write to it.
Tested on UNO, MEGA, DUE - same results.
Suggestions on how to proceed - please.
BTW - yes I did read the Adafruit SPI Fram breakout instructions. :)
LeeBurrow
Re: Fram problems
by adafruit_support_carter on Wed Mar 10, 2021 3:25 pm
Please post a photo of your setup showing how everything is connected. Let's use the UNO for testing and troubleshooting.
Re: Fram problems
by LeeBurrow on Thu Mar 11, 2021 4:11 pm
Photos as requested.
Please note that the FRAM is recognized and apparently can be read from (when running code samples from library) but unfortunately I cannot change any values.
LeeBurrow
Re: Fram problems
by adafruit_support_carter on Thu Mar 11, 2021 6:04 pm
Thanks. That looks OK. It sounds like maybe some of the write protection has been enabled. Is this a new board? Or have you already run some other sketches with it? If so, which ones?
Re: Fram problems
by LeeBurrow on Thu Mar 11, 2021 9:39 pm
I used the Framinfo example which appears to be working fine.
However when using the MB85RS64 example it always writes 0 for all Fram content.
Modified the MB85RS64 example to write specific values to several memory locations, however always shows 0 when retrieved.
FYI - I purchased several of these breakout boards so I replaced the board I was testing with another one and unfortunately got the same results.
LeeBurrow
Re: Fram problems
by adafruit_support_carter on Mon Mar 15, 2021 3:05 pm
That's this one?
https://github.com/adafruit/Adafruit_FR ... 5RS64V.ino
Are the header pins soldered on the breakout in your photo above?
Re: Fram problems
by LeeBurrow on Mon Mar 15, 2021 3:11 pm
yes of course.
LeeBurrow
Re: Fram problems
by hathach on Tue Mar 16, 2021 5:49 am
Hi, the current version requires sketch to pass the address size in bytes, since your FRAM size > 64 KB, it needs to be passed 3 bytes (default is 2). Please change the example to
  if (fram.begin(3)) {
    Serial.println("Found SPI FRAM");
We have updated the library to auto-detect and set the address size accordingly to the device JEDEC ID, will need a bit of review and release. The next version of the library will not need this modification any more simply `begin()` will work (FYI https://github.com/adafruit/Adafruit_FRAM_SPI/pull/18)
hathach
Re: Fram problems
by LeeBurrow on Wed Mar 17, 2021 9:57 am
Yup that fixed the problem. Works great.
LeeBurrow
