Adafruit Matrix Portal will not upload FastLED Examples
by LEDLIT1 on Tue Mar 16, 2021 12:24 pm
Hi ,
Please help. I have 4 Adafruit Matrix Portal M4 (SAMD51) connected with 4 Adafruit 64 x 32 Matixes and 4 strips of Neopixals. It all works, except for the FastLED errors. Fastpin.h seems to be calling out the error, but I am not sure, and I don't know how to edit the library myself. I need the FastLED library to control the Neopixels with several patterns I have coded over the years from other projects. This is a huge project for me, but I am badly stuck now with a deadline fast approaching.
Here is the detailed procedure I have taken using FastLED Blink to show you, and the error message below.
1. Open Arduino IDE version 1.8.13
2. I confirmed the latest version of FastLED, which is FastLED 3.4.0
3. Connected my Adafruit Matrix Portal M4 (SAMD51) to my Windows 10 PC USB
4. Tools>Board>Adafruit SAMD> selected Adafruit Matrix Portal M4 (SAMD51)
5. Tools>Port> selected com37 Adafruit Matrix Portal M4 (SAMD51) is showing
6. File>Examples>FastLED> select Blink
7. In the sketch I reassign #define DATA_PIN 3 to #define DATA_PIN A0
8. Click Upload
9. Error compiling for board Adadfruit Matrix Portal M4 (SAMD51) occurs
10. Copied and pasted the error message below.
11. The Fastpin.h seems to be calling out the error, but I am not sure.
12. I have tried ALL the FastLED examples with ALL the possible pins available on multiple Matrix Portal M4 (SAMD51) and have had the same errors for weeks now on and off hoping for an update.
Arduino: 1.8.13 (Windows 10), Board: "Adafruit Matrix Portal M4 (SAMD51), Enabled, 120 MHz (standard), Small (-Os) (standard), 50 MHz (standard), Arduino, Off"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\jlcel\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\jlcel\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\jlcel\Documents\Arduino\libraries -fqbn=adafruit:samd:adafruit_matrixportal_m4:cache=on,speed=120,opt=small,maxqspi=50,usbstack=arduino,debug=off -vid-pid=239A_80C9 -ide-version=10813 -build-path C:\Users\jlcel\AppData\Local\Temp\arduino_build_439064 -warnings=all -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.bossac.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.CMSIS.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.CMSIS-5.4.0.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.arduinoOTA.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.arm-none-eabi-gcc-9-2019q4.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.openocd.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -verbose C:\Users\jlcel\AppData\Local\Temp\arduino_modified_sketch_125443\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\jlcel\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\jlcel\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\jlcel\Documents\Arduino\libraries -fqbn=adafruit:samd:adafruit_matrixportal_m4:cache=on,speed=120,opt=small,maxqspi=50,usbstack=arduino,debug=off -vid-pid=239A_80C9 -ide-version=10813 -build-path C:\Users\jlcel\AppData\Local\Temp\arduino_build_439064 -warnings=all -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.bossac.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.CMSIS.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.CMSIS-5.4.0.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.arduinoOTA.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.arm-none-eabi-gcc-9-2019q4.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.openocd.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\jlcel\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -verbose C:\Users\jlcel\AppData\Local\Temp\arduino_modified_sketch_125443\Blink.ino
Using board 'adafruit_matrixportal_m4' from platform in folder: C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.6.5
Using core 'arduino' from platform in folder: C:\Users\jlcel\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.6.5
Detecting libraries used...
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "C:\\Users\\jlcel\\AppData\\Local\\Temp\\arduino_build_439064\\sketch\\Blink.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for FastLED.h: [FastLED-3.4.0@3.4.0]
ResolveLibrary(FastLED.h)
  -> candidates: [FastLED-3.4.0@3.4.0]
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src" "C:\\Users\\jlcel\\AppData\\Local\\Temp\\arduino_build_439064\\sketch\\Blink.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src\\FastLED.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src\\bitswap.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src\\colorpalettes.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src\\colorutils.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src\\hsv2rgb.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src\\lib8tion.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src\\noise.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src\\platforms\\esp\\32\\clockless_rmt_esp32.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src\\platforms.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src\\power_mgt.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src" "C:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src\\wiring.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src" "C:\\Users\\jlcel\\AppData\\Local\\Temp\\arduino_build_439064\\sketch\\Blink.ino.cpp" -o "C:\\Users\\jlcel\\AppData\\Local\\Temp\\arduino_build_439064\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\jlcel\\AppData\\Local\\Temp\\arduino_build_439064\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -Wall -Wextra -Wno-expansion-to-defined -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_MATRIXPORTAL_M4 -DARDUINO_ARCH_SAMD -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51J19A__ -DADAFRUIT_MATRIXPORTAL_M4_EXPRESS -DCRYSTALLESS -D__SAMD51__ -DUSB_VID=0x239A -DUSB_PID=0x80C9 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit LLC\"" "-DUSB_PRODUCT=\"Adafruit Matrix Portal M4\"" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\cores\\arduino" "-IC:\\Users\\jlcel\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.6.5\\variants\\matrixportal_m4" "-IC:\\Users\\jlcel\\Documents\\Arduino\\libraries\\FastLED-3.4.0\\src" "C:\\Users\\jlcel\\AppData\\Local\\Temp\\arduino_build_439064\\sketch\\Blink.ino.cpp" -o "C:\\Users\\jlcel\\AppData\\Local\\Temp\\arduino_build_439064\\sketch\\Blink.ino.cpp.o"
In file included from C:\Users\jlcel\AppData\Local\Temp\arduino_modified_sketch_125443\Blink.ino:1:
C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/FastLED.h:585:2: warning: #warning "No pin/port mappings found, pin access will be slightly slower. See fastpin.h for info." [-Wcpp]
  585 | #warning "No pin/port mappings found, pin access will be slightly slower. See fastpin.h for info."
C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/FastLED.h:14:21: note: #pragma message: FastLED version 3.004.000
   14 | #    pragma message "FastLED version 3.004.000"
In file included from C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/FastLED.h:65,
C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/fastspi.h:135:23: note: #pragma message: No hardware SPI pins defined.  All SPI access will default to bitbanged output
  135 | #      pragma message "No hardware SPI pins defined.  All SPI access will default to bitbanged output"
In file included from C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/FastLED.h:48,
C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/fastpin.h: In instantiation of 'class FastPin<22>':
C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/platforms/arm/d51/clockless_arm_d51.h:19:49:   required from 'class ClocklessController<22, 39, 39, 77, RGB, 0, false, 50>'
C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/chipsets.h:574:7:   required from 'class WS2813Controller<22, RGB>'
C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/FastLED.h:112:52:   required from 'class WS2813<22, RGB>'
C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/FastLED.h:302:39:   required from 'static CLEDController& CFastLED::addLeds(CRGB*, int, int) [with CHIPSET = WS2813; unsigned char DATA_PIN = 22; EOrder RGB_ORDER = RGB]'
C:\Users\jlcel\AppData\Local\Temp\arduino_modified_sketch_125443\Blink.ino:40:59:   required from here
C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/fastpin.h:210:24: error: static assertion failed: Invalid pin specified
  210 |  static_assert(validpin(), "Invalid pin specified");
In file included from C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/platforms/arm/d51/fastled_arm_d51.h:5,
                 from C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/platforms.h:32,
                 from C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/FastLED.h:52,
C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/platforms/arm/d51/clockless_arm_d51.h: In instantiation of 'static uint32_t ClocklessController<DATA_PIN, T1, T2, T3, RGB_ORDER, XTRA0, FLIP, WAIT_TIME>::showRGBInternal(PixelController<RGB_ORDER>) [with int DATA_PIN = 22; int T1 = 39; int T2 = 39; int T3 = 77; EOrder RGB_ORDER = RGB; int XTRA0 = 0; bool FLIP = false; int WAIT_TIME = 50; uint32_t = long unsigned int]':
C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/platforms/arm/d51/clockless_arm_d51.h:38:22:   required from 'void ClocklessController<DATA_PIN, T1, T2, T3, RGB_ORDER, XTRA0, FLIP, WAIT_TIME>::showPixels(PixelController<RGB_ORDER>&) [with int DATA_PIN = 22; int T1 = 39; int T2 = 39; int T3 = 77; EOrder RGB_ORDER = RGB; int XTRA0 = 0; bool FLIP = false; int WAIT_TIME = 50]'
C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/platforms/arm/d51/clockless_arm_d51.h:36:15:   required from here
C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/platforms/arm/d51/clockless_arm_d51.h:106:22: warning: address requested for 'b', which is declared 'register' [-Wextra]
  106 |    writeBits<8+XTRA0>(next_mark, port, hi, lo, b);
C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/fastpin.h: In instantiation of 'static void FastPin<PIN>::fastset(FastPin<PIN>::port_ptr_t, port_t) [with unsigned char PIN = 22; FastPin<PIN>::port_ptr_t = volatile long unsigned int*; RwReg = volatile long unsigned int; FastPin<PIN>::port_t = volatile long unsigned int]':
C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/platforms/arm/d51/clockless_arm_d51.h:49:30:   required from 'static void ClocklessController<DATA_PIN, T1, T2, T3, RGB_ORDER, XTRA0, FLIP, WAIT_TIME>::writeBits(uint32_t&, ClocklessController<DATA_PIN, T1, T2, T3, RGB_ORDER, XTRA0, FLIP, WAIT_TIME>::data_ptr_t, ClocklessController<DATA_PIN, T1, T2, T3, RGB_ORDER, XTRA0, FLIP, WAIT_TIME>::data_t, ClocklessController<DATA_PIN, T1, T2, T3, RGB_ORDER, XTRA0, FLIP, WAIT_TIME>::data_t, uint8_t&) [with int BITS = 8; int DATA_PIN = 22; int T1 = 39; int T2 = 39; int T3 = 77; EOrder RGB_ORDER = RGB; int XTRA0 = 0; bool FLIP = false; int WAIT_TIME = 50; uint32_t = long unsigned int; ClocklessController<DATA_PIN, T1, T2, T3, RGB_ORDER, XTRA0, FLIP, WAIT_TIME>::data_ptr_t = volatile long unsigned int*; ClocklessController<DATA_PIN, T1, T2, T3, RGB_ORDER, XTRA0, FLIP, WAIT_TIME>::data_t = volatile long unsigned int; uint8_t = unsigned char]'
C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/platforms/arm/d51/clockless_arm_d51.h:106:22:   required from 'static uint32_t ClocklessController<DATA_PIN, T1, T2, T3, RGB_ORDER, XTRA0, FLIP, WAIT_TIME>::showRGBInternal(PixelController<RGB_ORDER>) [with int DATA_PIN = 22; int T1 = 39; int T2 = 39; int T3 = 77; EOrder RGB_ORDER = RGB; int XTRA0 = 0; bool FLIP = false; int WAIT_TIME = 50; uint32_t = long unsigned int]'
C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/fastpin.h:232:49: warning: unused parameter 'port' [-Wunused-parameter]
  232 |  inline static void fastset(register port_ptr_t port, register port_t val) __attribute__ ((always_inline)) { }
C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0\src/fastpin.h:232:71: warning: unused parameter 'val' [-Wunused-parameter]
Using library FastLED-3.4.0 at version 3.4.0 in folder: C:\Users\jlcel\Documents\Arduino\libraries\FastLED-3.4.0
exit status 1
Error compiling for board Adafruit Matrix Portal M4 (SAMD51).
LEDLIT1
Re: Adafruit Matrix Portal will not upload FastLED Examples
by adafruit_support_carter on Tue Mar 16, 2021 1:26 pm
Looks like you are working this with the FastLED library supporters:
https://github.com/FastLED/FastLED/issues/1196
by LEDLIT1 on Wed Mar 17, 2021 9:29 am
Yes, That is my post at https://github.com/FastLED/FastLED/issues/1196 . I don't think any of the replies to it are talking it seriously. It's like they don't believe me something, when all's they have to do is select the Adadfruit Matrix Portal M4 (SAMD51) board in the Arduino IDE and try to compile any FastLED example. It will be clear that something is up if they simply did that.
So, my best guess at this point is that the FastLED library is not being maintained fully, and this sort of thing will be happening more and more as other new boards are released. I need to convert all my fastLED code to Adadfruit Neopixel at this point.
LEDLIT1
