Brushless motor--built in driver using Adrafruit Motor Shiel
by penapv on Thu Mar 25, 2021 2:38 pm
I'm hoping to add a small brushless motor with following specs using motor shield v2.3 and arduino. I'm trying to avoid using an ESC and LIPO battery to run. Would it be possible to run the motor through PWM and powered through the motor shield?
59e6ba9c_2418BL.pdf
(157.38 KiB) Downloaded 2 times
Rated Voltage : 6V DC
No-load speed : 10300 RPM
No-load Current : 190 mA
Rated Torque : 2.45 mN.m
Rated speed : 7800 rpm
Rated Current : 0.67 A
Power : 2 w
Stall Torque : 11.06 mN.m
Stall Current : 2.22 A
penapv
Re: Brushless motor--built in driver using Adrafruit Motor S
by adafruit_support_bill on Thu Mar 25, 2021 2:47 pm
Hard to say without more detailed specs.
"Yellow = Signal" - what are the input characteristics of this signal? What does it do that the direction and speed control do not?
"Blue = CW/CCW adjusting" - What is the voltage of the signal? What are the signal levels for CW and CCW?
"White = PWM Speed adjusting" - What is the voltage of the PWM signal? Is there a min or max acceptable frequency?
