powerboost shield 500mA appears shorted
by socrates1024 on Fri Mar 26, 2021 2:50 pm
I'm having a problem with a powerboost shield 500mA that arrived this week. Order number is 2520755-0759996712
After using it just fine for 20 minutes or so, it stopped working. It behaves exactly the same way as reported in this forum post viewtopic.php?f=31&t=174843&p=852912&hilit=powerboost#p852912 ....
basically when powered by microUSB the charging light is on but otherwise no functionality. Based on the discussion in the linked post above, I confirmed with a continuity checker there's a short across VBat and Gnd. I don't see any reason my downstream project (I stacked it with a servo shield and a metro from this order) would have caused this.
Attaching photos of my soldering
socrates1024
Re: powerboost shield 500mA appears shorted
by franklin97355 on Wed Apr 07, 2021 4:12 pm
Soldering looks good. What battery do you use and, if it was not an Adafruit product did you confirm the polarity?
franklin97355
by socrates1024 on Fri Apr 09, 2021 10:45 am
Thanks for the reply - I only used the 1200mah 3.7v battery that came with the powerboost shield
socrates1024
by franklin97355 on Wed Apr 21, 2021 2:54 pm
Sorry for the delay. Contact support@adafruit.com and we can replace the shield to see if it is actually shorted.
franklin97355
by socrates1024 on Fri May 07, 2021 4:35 pm
The replacement powerboost shield did the exact same thing after attaching it to an adafruit metro.
I observed that it was making a humming/whining sound while running on the battery prior to the light going off and then acting as described above. I don't know if that gives a hint as to what could be going wrong?
socrates1024
