MotorShield Failure
MotorShield Failure
by Sportsfan927 on Tue Mar 30, 2021 7:45 pm
I have a motor shield connected to an Uno PCB that I purchased in February. I when I installed it this past weekend, and tried to upload a sketch, none of the three DC motors connected moved. This makes me think I received the PCB as defective. How do I go about getting a replacement?
Thank you!
Chris
Sportsfan927
Re: MotorShield Failure
by adafruit_support_bill on Tue Mar 30, 2021 8:07 pm
Please post photos showing your soldering and connections to the shield.
Also please post specs for the motors and power supply you are using.
by Sportsfan927 on Wed Mar 31, 2021 1:06 am
Below are photos of the soldering and the connections in the power blocks. The power supply connected to the shield is a 12v 3a plug-in wall adapter. The rumble motors I am wanting to drive are the same as those found in a PlayStation controller. Please let me know if I can provide any additional info.
Thank you!
Chris
Sportsfan927
by adafruit_support_bill on Wed Mar 31, 2021 6:57 am
The power LED is not lit. Check the polarity of your power supply. The black wire is usually the ground wire and you have the black wire connected to the '+' terminal.
Is there a part number for those motors?
by Sportsfan927 on Wed Mar 31, 2021 1:20 pm
The power LED is not on because the board was unplugged from my wall adapter at the time of the photo. When it is plugged in the LED glows bright green. The color of wires was not considered when I was assembling this connection, however the polarity of the wall adapter and its connection to the board are correct.
As for the motors, I do not have a part number. However, I have included some photos below:
s-l1600 (1)_edited.jpg (34.73 KiB) Viewed 243 times
Sportsfan927
by adafruit_support_bill on Wed Mar 31, 2021 1:28 pm
Do you have a multimeter? Can you measure the current draw of the motor when powered directly from your power supply?
by Sportsfan927 on Wed Mar 31, 2021 3:12 pm
One motor connected to the power supply draws 0.534 amps.
Sportsfan927
by adafruit_support_bill on Wed Mar 31, 2021 3:39 pm
And what do you see on the serial monitor when you run the i2c scanner?
https://playground.arduino.cc/Main/I2cScanner/
by Sportsfan927 on Thu Apr 01, 2021 12:34 am
This is the result from uploading the i2c scanner:
23:39:45.245 -> Scanning...
23:39:45.280 -> No I2C devices found
I tried separating the shield and re-joining it and had the same results. Let me know what our next steps are.
Thank you!
Chris
Sportsfan927
by adafruit_support_bill on Thu Apr 01, 2021 6:10 am
Sounds like the PCA9685 chip on the board is not functioning. We can replace the shield for you. Please contact support@adafruit.com with a link to this thread.
