Music Maker, Couldn't find VS1053
by eranbenjamin on Sun Apr 04, 2021 3:15 am
1. I am using an Adafruit "Music Maker" (MM) MP3 Shield (order #2511924-8852141374) connected to an Arduino MEGA by stacable headers (see picture).
2. The MM Sheild ICSP connections (namely MISO, SCK, and MOSI) are shorted as instructed.
3. SW:
a. I uploaded the “Player_Simple” sketch.
b. In the Adafruit_VS1053.cpp file, I have uncommented the following lines:
dumpRegs();
Serial.print("Version = "); Serial.println(v);
c. The output is:
Adafruit VS1053 Library Test
Mode = 0x0
Stat = 0x0
ClkF = 0x0
Vol. = 0x0
Version = 0
Couldn't find VS1053, do you have the right pins defined?
4. I am following the Learning System @ https://learn.adafruit.com/adafruit-mus ... play-music
Can you please advice? What I am missing?
image4reduce less.jpeg (864.69 KiB) Viewed 229 times
eranbenjamin
Re: Music Maker, Couldn't find VS1053
by adafruit_support_carter on Mon Apr 05, 2021 1:38 pm
by eranbenjamin on Thu Apr 08, 2021 3:42 pm
I have all pins soldered: See the attached images: Top and Bottom side of the Music Maker board, AND the MM board connected to the Arduino MEGA 2560.
Still, same response:
-------------------------- >0 --------------------------
Mode = 0x0
Stat = 0x0
ClkF = 0x0
Vol. = 0x0
Version = 0
Any idea? Am I missing something?
In addition, the audio jack pop back 1-2 mm after inserting it to the audio socket. is that ok?
eranbenjamin
by adafruit_support_carter on Thu Apr 08, 2021 4:10 pm
Thanks. That soldering looks great!
In the example sketch, did you change these lines up?
  // create breakout-example object!
  Adafruit_VS1053_FilePlayer(BREAKOUT_RESET, BREAKOUT_CS, BREAKOUT_DCS, DREQ, CARDCS);
  // create shield-example object!
  //Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
You'll want to comment out the breakout line and uncomment the shield line.
by eranbenjamin on Thu Apr 08, 2021 4:20 pm
I changed (I did that initially but then downloaded again without changing).
It works!
Thank you.
eranbenjamin
