Music Maker's SD card as a data logger
by eranbenjamin on Fri Apr 09, 2021 3:08 pm
I have a music maker board (https://www.adafruit.com/product/1790).
I would like to use the SD card on the board as a logger.
Can I use the same code as in the data-logger shield (https://learn.adafruit.com/adafruit-data-logger-shield)?
If not - is there any other example/protocol I can use for having the SD card as a logger?
If the answer for both question is No, I would have to purchase the data-logger-shield (for having SD card's read/write capabilities), right?
eranbenjamin
Re: Music Maker's SD card as a data logger
by mikeysklar on Sat Apr 10, 2021 5:09 pm
@eranbenjamin,
It is possible you could get the music maker to work as a datalogger. I've seen an instant of it in the forums, but there are two issues:
1) This music maker was not designed for this so be prepared to deal with a lot of issues due to conflicts with the VS1053 on the same SPI bus.
2) This is pretty old hardware to invest development time into.
viewtopic.php?f=8&t=57546
We have some sweet TFT, FeatherWings and SD card breakout boards that can work as loggers with a lot less effort. I would recommend using one of those over fighting with the MusicMaker.
https://www.adafruit.com/?q=microSD+bre ... =BestMatch
mikeysklar
