Adafruit 16-channel PWM/Servo Shield controlled with sensors
by maybe_both on Sat Apr 24, 2021 11:33 am
Hi! I'm a first time poster.
I have an Adafruit 16-channel PWM/Servo Shield on an Arduino Uno Rev3, I've got it working with the help of this guide https://learn.adafruit.com/adafruit-16-channel-pwm-slash-servo-shield and am able to drive 4 servos for now, I'm using the testcode from previous url. Here is how it looks: https://imgur.com/unj1RCD
The Arduino is powered by USB via computer for now, and the shield is powered by a switching mode power supply with 5V, 2.5A, for now.
My question is if there is any way to control the servos using any kind of sensor, for example a motion sensor, and if it is possible then where do I start? Is there anywhere on the shield where I can plug it in somehow?
Grateful for any help I can get :)
Elin
maybe_both
Re: Adafruit 16-channel PWM/Servo Shield controlled with sen
by adafruit_support_bill on Sat Apr 24, 2021 1:19 pm
Sensors can provide input to your program and your program can use that to control the servos. You first need to decide what you want your project to do so you can select the appropriate sensors.
The shield has a prototyping area and breakout holes for all of the Arduino pins. So there are many ways to connect a sensor.
by maybe_both on Sun Apr 25, 2021 12:26 pm
adafruit_support_bill wrote:Sensors can provide input to your program and your program can use that to control the servos. You first need to decide what you want your project to do so you can select the appropriate sensor
Yay, it is possible! My idea is to get a sculpture moving when someone comes close to it, I was thinking about using a HC-SR04 ultrasonic sensor (for example) and when visitors comes to take a closer look they would see the sculpture doing a little "dance". Is this a good sensor for this?
maybe_both wrote:The shield has a prototyping area and breakout holes for all of the Arduino pins. So there are many ways to connect a sensor.
Oh okay, where is the prototyping area and how do I use it? I've searched online but can't find any projects doing this.
Thank you, Bill :)
maybe_both
by jglogau on Thu Apr 29, 2021 1:49 am
Hello:
I just got a Adafruit 16-channel PWM - B, soldered it up and connected the USB to my Mega (Not a regular Uno or clone) and the power (5V 2A) to your Shield.
I am NOT getting both the red and green lights on, ONLY the green LED. So the servo isn't running with the demo code "servo"
I assume that the red and green lights are referring to LEDs on the Shield, not the Mega.
What am I doing wrong?
Is the wiring somewhat different for the Mega?
Here's a picture, is the soldering OK, can't get it any higher resolution?
Adafruit 16 -channel PWM/Servo Shield with Arduino Mega
Thank you
jglogau
by adafruit_support_bill on Thu Apr 29, 2021 5:29 am
That is a good sensor. It can measure distance, so you can tell how close the visitor is to the sculpture.
That is the grid of holes that takes up half the board. You can use that any way you like to mount components and connect them together.
by adafruit_support_bill on Thu Apr 29, 2021 5:30 am
@jglogau - To avoid confusion, please start a new thread for your question.
posting.php?mode=post&f=31
