SD cardAdafruit 2.4" TFT FeatherWing
by alainsam on Sun May 09, 2021 11:10 pm
Can the SD card in the Adafruit 2.4" TFT FeatherWing be uses as a data loger?
alainsam
Re: SD cardAdafruit 2.4" TFT FeatherWing
by dastels on Mon May 10, 2021 11:24 am
Sure. It's just an SD card. You just have to mount it, open a file(s), and write to it. Have a look at the bottom of https://learn.adafruit.com/adafruit-2-4-tft-touch-screen-featherwing/pinouts to find the CS pin for it on the Feather you are using.
dastels
by alainsam on Tue May 11, 2021 4:22 pm
Thanks but I am a bit confuse about the pin number on the ESP8266. For example the pin 2 for SD is that the physical pin #5 starting pin#1 at the left side of the USB connector?
alainsam
by alainsam on Thu May 13, 2021 6:58 pm
I'm trying to use the SD in the TFT Featherwing. + 8266 Feather
I have a 128GB card from SANDISK Ultra Formated as required
I" am using the SDInfo exemple modified for CS = 2
I got stuck with "File System initialization failed" error. and need help
I get the following output when running the program:
type any character to start
init time: 13 ms
Card type: SDXC
Manufacturer ID: 0X3
OEM ID: SD
Product: SD128
Version: 8.5
Serial number: 0XB79A5FC5
Manufacturing date: 8/2014
cardSize: 127865.45 MB (MB = 1,000,000 bytes)
flashEraseSize: 128 blocks
eraseSingleBlock: true
OCR: 0XC0FF8000
SD Partition Table
part,boot,type,start,length
1,0X0,0X7,32768,249704448
2,0X0,0X0,0,0
3,0X0,0X0,0,0
4,0X0,0X0,0,0
error:
File System initialization failed.
alainsam
