#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <Adafruit_VS1053.h>
#include "Adafruit_MPR121.h"
// These are the pins used
#define VS1053_RESET -1 // VS1053 reset pin (not used!)
// Feather ESP8266
#if defined(ESP8266)
#define VS1053_CS 16 // VS1053 chip select pin (output)
#define VS1053_DCS 15 // VS1053 Data/command select pin (output)
#define CARDCS 2 // Card chip select pin
#define VS1053_DREQ 0 // VS1053 Data request, ideally an Interrupt pin
// Feather ESP32
#elif defined(ESP32)
#define VS1053_CS 32 // VS1053 chip select pin (output)
#define VS1053_DCS 33 // VS1053 Data/command select pin (output)
#define CARDCS 14 // Card chip select pin
#define VS1053_DREQ 15 // VS1053 Data request, ideally an Interrupt pin
// Feather Teensy3
#elif defined(TEENSYDUINO)
#define VS1053_CS 3 // VS1053 chip select pin (output)
#define VS1053_DCS 10 // VS1053 Data/command select pin (output)
#define CARDCS 8 // Card chip select pin
#define VS1053_DREQ 4 // VS1053 Data request, ideally an Interrupt pin
// WICED feather
#elif defined(ARDUINO_STM32_FEATHER)
#define VS1053_CS PC7 // VS1053 chip select pin (output)
#define VS1053_DCS PB4 // VS1053 Data/command select pin (output)
#define CARDCS PC5 // Card chip select pin
#define VS1053_DREQ PA15 // VS1053 Data request, ideally an Interrupt pin
#elif defined(ARDUINO_NRF52832_FEATHER )
#define VS1053_CS 30 // VS1053 chip select pin (output)
#define VS1053_DCS 11 // VS1053 Data/command select pin (output)
#define CARDCS 27 // Card chip select pin
#define VS1053_DREQ 31 // VS1053 Data request, ideally an Interrupt pin
// Feather M4, M0, 328, nRF52840 or 32u4
#else
#define VS1053_CS 6 // VS1053 chip select pin (output)
#define CARDCS 5 // Card chip select pin
// DREQ should be an Int pin *if possible* (not possible on 32u4)
#define VS1053_DREQ 9 // VS1053 Data request, ideally an Interrupt pin
#endif
#ifndef _BV
#define _BV(bit) (1 << (bit))
#endif
Adafruit_VS1053_FilePlayer musicPlayer =
Adafruit_VS1053_FilePlayer(VS1053_RESET, VS1053_CS, VS1053_DCS, VS1053_DREQ, CARDCS);
Adafruit_MPR121 cap = Adafruit_MPR121();
// Keeps track of the last pins touched
// so we know when buttons are 'released'
uint16_t lasttouched = 0;
uint16_t currtouched = 0;
Serial.begin(115200);
while (!Serial) { // needed to keep leonardo/micro from starting too fast!
delay(10);
if (!cap.begin(0x5A)) {
Serial.println("MPR121 not found, check wiring?");
while (1);
// initialise the music player
if (!musicPlayer.begin()) {
Serial.println(F("Couldn't find VS1053"));
while (1);
if (!SD.begin(CARDCS)) {
Serial.println(F("SD failed, or not present"));
while (1);
// Set volume for left, right channels. lower numbers == louder volume!
musicPlayer.setVolume(30,30);
// Get the currently touched pads
currtouched = cap.touched();
for (uint8_t i=0; i<1; i++) {
// it if *is* touched and *wasnt* touched before, alert!
if ((currtouched & _BV(i)) && !(lasttouched & _BV(i)) ) {
Serial.print(i); Serial.println(" touched");
if (i == 0 && musicPlayer.stopped()) {
Serial.println(" starting");
musicPlayer.startPlayingFile("/inevit.wav");
// if it *was* touched and now *isnt*, alert!
if (!(currtouched & _BV(i)) && (lasttouched & _BV(i)) ) {
Serial.print(i); Serial.println(" released");
if (i == 0 && !musicPlayer.stopped()) {
Serial.println(" stopping");
musicPlayer.stopPlaying();
// reset our state
lasttouched = currtouched;
