I've been working with MIDI files using the Music Maker in MIDI mode with the MD_MIDIFile library. Recently I started using LEDs via the TLC5947 driver (love these!). I'm now moving to the Arduino MKR Zero for using Scheduler. Unfortunately, MD_MIDIFile uses the SdFat library, not SD; and I can't get the SdFat library to work with the MKR Zero. I've been able to read the SD card using the SD library, I'm sure of the setup / SD Card itself. But when I use SdFat, the card fails initialization. I have set the select to SDCARD_SS_PIN to no avail.
Has anyone worked with MD_MIDIFile, or more specifically the SdFat library and the MKR Zero? I figure I'm missing something - just haven't been able to put my finger on what.
Adafruit MusicMaker, TLC5947, MKR Zero, and SD or SdFat
- mbkrueger
Re: Adafruit MusicMaker, TLC5947, MKR Zero, and SD or SdFat
I'm afraid we don't have any experience with that. Maybe someone from the community will know more.
You might also want to check in the Arduino forums: https://forum.arduino.cc/
