Using Arduino IDE 1.8.12 and WaveHC library 1.0.3 the output using the SDreadtest sketch is:
init time: 20
Card type: SD1
Manufacturer ID: 1D
OEM ID: AD
Product: SD
Version: 0.0
Serial number: 118620160
Manufacturing date: 9/2006
card size: 501760 (512 byte blocks)
partion,boot,type,start,length
1,0,6,2048,499712
2,0,0,0,0
3,0,0,0,0
4,0,0,0,0
Read test starting. Please Wait.
Read 20000 blocks
mills: 20610
Done
Wave test!
Free RAM: 619
Using partition 1, type is FAT16
Files found (* = fragmented):
0.WAV
1.WAV
2.WAV
3.WAV
4.WAV
5.WAV
6.WAV
7.WAV
8.WAV
9.WAV
P.WAV
Playing 0.WAVDVOLUME must be set to non-zero in WaveHC.h
Not a valid WAV
Playing 1.WAVDVOLUME must be set to non-zero in WaveHC.h
Not a valid WAV
Playing 2.WAVDVOLUME must be set to non-zero in WaveHC.h
Not a valid WAV
Playing 3.WAVDVOLUME must be set to non-zero in WaveHC.h
Not a valid WAV
Playing 4.WAVDVOLUME must be set to non-zero in WaveHC.h
Not a valid WAV
Playing 5.WAVDVOLUME must be set to non-zero in WaveHC.h
Not a valid WAV
Playing 6.WAVDVOLUME must be set to non-zero in WaveHC.h
Not a valid WAV
Playing 7.WAVDVOLUME must be set to non-zero in WaveHC.h
Not a valid WAV
Playing 8.WAVDVOLUME must be set to non-zero in WaveHC.h
Not a valid WAV
Playing 9.WAVDVOLUME must be set to non-zero in WaveHC.h
Not a valid WAV
Playing P.WAVDVOLUME must be set to non-zero in WaveHC.h
Not a valid WAV
Any assistance would be greatly appreciated.
