I have a small test I'm doing with a V2 motor shield, a small motor, and a rotary encoder. I run the motor, and after 100 rises of the interrupt pin the motor should stop. The motor runs but never stops or exits the WHILE loop after it enters, even though my output shows more than 100 pulses from the encoder. I tried as a test running the motor, delaying 3 seconds and then stopping, but like before the motor never stops after the 3 seconds is up. Ive tried with UNO's interrupt pins 2 and 3 and with all the interrupt pins of a Mega with the same results. (SCL/SDA the motor doesn't run at all of course, as that I assume is used by the shield). If I remove the interrupt in the code, the motor stops and starts fine. I'm not really sure what is happening here, but it seems as though you can't use motor encoders with interrupts at all! I've found nothing in searches or docs regarding this subject. Here's the code:
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_MS_PWMServoDriver.h"
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_DCMotor *motor = AFMS.getMotor(1);
unsigned int counter = 0;
void ISR_count1()
counter++; // increment Motor 1 counter value
Serial.print("Counter: ");
Serial.println(counter);
void Move(){
delay(3000);
counter = 0;
while ( (counter < 100)) {
motor->setSpeed(100);
motor->run(FORWARD);
Serial.println("Goal reached!");
motor->setSpeed(0);
delay(3000);
AFMS.begin();
attachInterrupt(digitalPinToInterrupt (3), ISR_count1, RISING);
Serial.begin(9600);
Move();
