Hello guys, I am porting a project originally based on an Arduino Mega 2560 using a Music Maker Shield to a Wemos D1 R32 MCU board (it is compatible with EspDuino32) but it does not work. Both boards are working and I think it is not an HW problem (the 4050 buffer is not needed because both boards work at 3.3V but the board may work also without removing it) so i suspect it is a SW problem, may be in pin definitions.
These are my original pin definitions for the Mega2560:
#include <Adafruit_VS1053.h>
#define VS1053_RESET -1
#define VS1053_CS 7
#define VS1053_DCS 6
#define VS1053_DREQ 3
#define CARDCS 4
and they should be OK for the ESP32 board also so I do not understand where the problem is.
Was anyone able to make the Music Maker shield working with any ESP32 based board?
Music Shield and ESPDuino32
- mikeysklar
Re: Music Shield and ESPDuino32
We do have some examples code with the Feather based MusicMaker shield using ESP32 and ESP32-S2 hardware. This Feather MusicMaker is different than the shield you have so I would not expect these pinouts to just work, but might be of value to review.
https://github.com/adafruit/Adafruit_VS ... player.ino
// Feather ESP32
#elif defined(ESP32) && !defined(ARDUINO_ADAFRUIT_FEATHER_ESP32S2)
#define VS1053_CS 32 // VS1053 chip select pin (output)
#define VS1053_DCS 33 // VS1053 Data/command select pin (output)
#define CARDCS 14 // Card chip select pin
#define VS1053_DREQ 15 // VS1053 Data request, ideally an Interrupt pin
// Feather M4, M0, 328, ESP32S2, nRF52840 or 32u4
#else
#define VS1053_CS 6 // VS1053 chip select pin (output)
#define VS1053_DCS 10 // VS1053 Data/command select pin (output)
#define CARDCS 5 // Card chip select pin
// DREQ should be an Int pin *if possible* (not possible on 32u4)
#define VS1053_DREQ 9 // VS1053 Data request, ideally an Interrupt pin
#endif
