Just wondering if any of AdaFruit's Metro cards are recommended for use with the gShield?
I understand that the Metro cards are somewhat compatible?
But my big concern is if a Metro will be "plug&play", as it were, with the grbl 1.1
Looking for a setup that requires as little a deviation from standard as possible as far as crawling under the hood and tweaking code goes. I hear it is possible to use a Raspberry Pi and cnc.js as a web-based portal to control grbl, this is my end goal.
Thanks for your time,
-Tim
gShield and the Metro
Re: gShield and the Metro
The Metro 328 is pin-compatible with the Arduino UNO. So it will 'plug & play' with the GShield.
