There are TWO SD libraries!
One is in the Sketches folder and the other is (on a Mac) in /Applications/Arduino.app/Contents/Java/libraries/SD
You have two guesses as to which one I replaced. Hint: It was the one in /Applications.
Why?
On web page: https://learn.adafruit.com/adafruit-dat ... d-leonardo
It states:
First, find the "core libraries" folder - if you are using Windows or Linux, it will be in the folder that contains the Arduino executable, look for a libraries folder. Inside you will see an SD folder (inside that will be SD.cpp SD.h etc)
So, silly me....I reasoned that on the Mac I should also look in the folder (aka "Container" in Macspeak) for Arduino.app for a library called SD that has (in a subfolder called src), files SD.cpp, SD.h.
And sure enough those files are there.
Bottom line: On the Mac replace the SD folder in /Sketches/libraries/ and NOT in /Applications/Arduino.app/Contents/Java/libraries/SD.
When you change the correct SD library cardinfo works fine.
Admin: Feel free to delete this thread if it's appropriate to do so.
Cheers
Andy
---------- ORIGINAL POST-----
I'm trying to use one of the older Adafruit Datalogger shields, Product 1141 on a Mega 2560 R3 with IDE 1.8.19 running on a Mac under Big Sur.
I noted the web page that I had to change out the SD library for the Mega and did that.
I also noted the web page at https://learn.adafruit.com/adafruit-dat ... d-leonardo that provides instructions for the Mega and older Datalogger without the SPI port connection.
I followed the instructions specifically to see if I could get the cardinfo sketch to work. Specifically the instruction that says "The cardinfo sketch uses a lower level library to talk directly to the card, so it calls card.init() instead of SD.begin()." and then shows how to change the line:
// we'll use the initialization code from the utility libraries
// since we're just testing if the card is working!
while (!card.init(SPI_HALF_SPEED, chipSelect)) {
while (!card.init(SPI_HALF_SPEED, 10, 11, 12, 13)) {
Question 1: The first is that in the cardinfo sketch line 50 has an if not a while (but I suspect this is of no great consequece):
if (!card.init(SPI_HALF_SPEED, chipSelect)) {
I realize that I may have to go "weed diving®" into the class library, but I reasoned I'm unlikely to be the first person with this problem and/or adafruit might take pity on me!
Anyone figured a workaround for this please? (Be gentle please, I'm an experienced systems programmer but new to Arduino/Mega/SD cards!) :)
Thanks in advance
Andy
Arduino: 1.8.19 (Mac OS X), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
/Users/andy/Dropbox/Arduino/Sketches/SDCardInfo/SDCardInfo/SDCardInfo.ino: In function 'void setup()':
SDCardInfo:50:48: error: no matching function for call to 'Sd2Card::init(const uint8_t&, int, int, int, int)'
if (!card.init(SPI_HALF_SPEED, 10, 11, 12, 13)) {
In file included from /Users/andy/Dropbox/Arduino/Sketches/libraries/SD/src/utility/SdFat.h:29:0,
from /Users/andy/Dropbox/Arduino/Sketches/libraries/SD/src/SD.h:20,
from /Users/andy/Dropbox/Arduino/Sketches/SDCardInfo/SDCardInfo/SDCardInfo.ino:24:
/Users/andy/Dropbox/Arduino/Sketches/libraries/SD/src/utility/Sd2Card.h:193:11: note: candidate: uint8_t Sd2Card::init()
uint8_t init(void) {
/Users/andy/Dropbox/Arduino/Sketches/libraries/SD/src/utility/Sd2Card.h:193:11: note: candidate expects 0 arguments, 5 provided
/Users/andy/Dropbox/Arduino/Sketches/libraries/SD/src/utility/Sd2Card.h:201:11: note: candidate: uint8_t Sd2Card::init(uint8_t)
uint8_t init(uint8_t sckRateID) {
/Users/andy/Dropbox/Arduino/Sketches/libraries/SD/src/utility/Sd2Card.h:201:11: note: candidate expects 1 argument, 5 provided
/Users/andy/Dropbox/Arduino/Sketches/libraries/SD/src/utility/Sd2Card.h:204:11: note: candidate: uint8_t Sd2Card::init(uint8_t, uint8_t)
uint8_t init(uint8_t sckRateID, uint8_t chipSelectPin);
/Users/andy/Dropbox/Arduino/Sketches/libraries/SD/src/utility/Sd2Card.h:204:11: note: candidate expects 2 arguments, 5 provided
Multiple libraries were found for "SD.h"
Used: /Users/andy/Dropbox/Arduino/Sketches/libraries/SD
Not used: /Applications/Arduino.app/Contents/Java/libraries/SD
exit status 1
