How to get to work with ILI9341 touch (Resistive)
- next93
I am using ILI9341 resistive touch display by Adafruit for the first time and the link of the display is https://www.adafruit.com/product/1770 using it with the Arduino Due. I am working to make the touchscreen work in the display. Tested touch with the TouchScreen library available here https://github.com/adafruit/Adafruit_TouchScreen and it worked well. I want to use Adafruit_GFX_Button and the functions justPressed() and justReleased() to create a touch UI need some help on that it seemed to be not working. What may be wrong?
- mikeysklar
Re: How to get to work with ILI9341 touch (Resistive)
Are you using the 8-bit or SPI wiring configuration?
There is a “wiring and test” section for each that might help with getting the touch going.
https://learn.adafruit.com/adafruit-2-8 ... g-and-test
