I've displayed the code below
#include <SD.h>
#include "TFTv2.h"
#define MAX_BMP 25 // Maximum number of BMP files
#define FILENAME_LEN 16 // Maximum file name length
#define SKETCH "TFT_Mod1 / Rev2"
// Determine how a file will be displayed, sweeping the screen vertically:
#define DOWN 0 // display from top to bottom
#define UP 1 // display from bottom to top
#define IN 2 // display from top/bottom in to center
#define OUT 3 // display from center out to top/bottom
const int PIN_SD_CS = 4; // pin of sd card
// Display pixel size, as defined in TFTv2.h
uint32_t DspHeight = MAX_Y + 1;
uint32_t DspWidth = MAX_X + 1;
float DspAr = (float)DspHeight / (float)DspWidth; // Aspect Ratio
// Specify the BMP file read buffer
#define BUFFPIXEL 400
uint8_t SdBuffer[BUFFPIXEL * 3]; // Allow for color depth of 3 bytes/pixel
uint16_t PixelColor[MAX_X + 1];
// BMP File specifcations
uint16_t NumBmpFiles = 0; // Number of BMP files
char BmpFiles[MAX_BMP][FILENAME_LEN]; // List of image files
char* fileName; // Current file on display
uint32_t fileSize;
uint32_t BmpImageOffset = 0; // Offset of image in the BMP file
uint32_t BmpHeight; // BMP image pixel height
uint32_t BmpWidth; // BMP image pixel width
uint8_t BmpDepth;
File BmpFile;
// search root to find bmp file
void searchDirectory() {
File root = SD.open("/"); // root
while (NumBmpFiles < MAX_BMP) {
File entry = root.openNextFile();
if (!entry) {
break;
if (!entry.isDirectory()) {
String name = entry.name();
int len = name.length();
if (len >= 5 && len <= 12) {
strcpy(BmpFiles[NumBmpFiles], name.c_str());
name.toUpperCase();
if (name.endsWith(".BMP")) {
NumBmpFiles++;
entry.close();
Serial.print("get ");
Serial.print(NumBmpFiles);
Serial.println(" files: ");
for (int i = 0; i < NumBmpFiles; i++) {
Serial.println(BmpFiles[i]);
Serial.println();
Serial.begin(115200);
Serial.println(F(SKETCH));
pinMode(PIN_SD_CS, OUTPUT);
Tft.TFTinit();
Sd2Card card;
card.init(SPI_FULL_SPEED, PIN_SD_CS);
if (!SD.begin(PIN_SD_CS)) {
Serial.println("SD failed!");
while (1); // init fail, die here
Serial.println("SD OK!");
searchDirectory();
TFT_BL_ON;
static int dirCtrl = UP;
for (unsigned char i = 0; i < NumBmpFiles; i++) {
fileName = BmpFiles[i];
BmpFile = SD.open(fileName);
if (!BmpFile) {
Serial.print("didnt find image: ");
Serial.println(fileName);
break;
if (!bmpReadHeader(BmpFile)) {
Serial.println("bad bmp");
break;
bmpdraw(BmpFile, dirCtrl);
BmpFile.close();
dirCtrl = (dirCtrl + 1) % 4;
// This procedure reads a bitmap and draws it to the screen
// its sped up by reading many pixels worth of data at a time
// instead of just one pixel at a time. Increasing the buffer takes
// more RAM but makes the drawing a little faster. 20 pixels' worth
// is probably a good place
// dir - DOWN: sweep top to bottom
// dir - UP: sweep bottom to top
// dir - IN: sweep from edge to center
// dir - OUT: sweep from center to edge
void bmpdraw(File f, int my_dir) {
Display the BMP file.
If the image is narrower than the screen (BmpWidth < DspWidth),
then center the display on the width.
If the image is shorter than the display (BmpHeight < DspHeight),
then center the image on the display height.
If the image is wider than the screen (BmpWidth > DspWidth),
then crop the image width from both sides.
If the image is taller than the display (BmpHeight > DspHeight),
then crop the image width from both top and bottom
int dir = my_dir == IN || my_dir == OUT ? UP : my_dir;
// Compute scanline padding
uint8_t padding = 0;
uint16_t scanlinebytes = BmpWidth * BmpDepth;
while ((scanlinebytes + padding) % 4 != 0) {
padding++;
uint32_t time = millis(); // Milliseconds taken to display the image
uint16_t offset_x = 0, // Display Width Margin
offset_y = 0; // Display Height Margin
float skip = 1.0; // Image Shrink Factor
float BmpAr = (float)BmpHeight / (float)BmpWidth; // Image Aspect Ratio
bool done_y = false;
// First check to see if the image needs to shrink to fit onto the display:
if (BmpWidth > DspWidth || BmpHeight > DspHeight) {
if (BmpAr >= DspAr) {
skip = (float)BmpHeight / (float)DspHeight;
offset_x = (uint32_t)((float)DspWidth - (float)DspHeight / BmpAr) / 2;
} else {
skip = (float)BmpWidth / (float)DspWidth;
offset_y = (uint32_t)((float)DspHeight - (float)DspWidth * BmpAr) / 2;
} else {
if (BmpWidth < DspWidth) {
offset_x = (DspWidth - BmpWidth) / 2;
if (BmpHeight < DspHeight) {
offset_y = (DspHeight - BmpHeight) / 2;
#if(1)
Serial.print(F("\nFile: "));
Serial.print(F("Size: "));
Serial.println(fileSize);
Serial.print(F("dir = "));
switch (my_dir) {
case UP: {
Serial.println(F("UP"));
break;
case DOWN: {
Serial.println(F("DOWN"));
break;
case IN: {
Serial.println(F("IN"));
break;
case OUT: {
Serial.println(F("OUT"));
break;
#endif
#if(1)
Serial.print(F("padding: "));
Serial.println(padding);
Serial.print(F("DspWidth, DspHeight = "));
Serial.print(DspWidth);
Serial.print(F(", "));
Serial.println(DspHeight);
Serial.print(F("BmpDepth = "));
Serial.println(BmpDepth);
Serial.print(F("BmpWidth, BmpHeight = "));
Serial.print(BmpWidth);
Serial.println(BmpHeight);
Serial.print(F("BmpAr, DspAr = "));
Serial.print(BmpAr);
Serial.println(DspAr);
Serial.print(F("skip = "));
Serial.println(skip);
Serial.print(F("offset_x, offset_y = "));
Serial.print(offset_x);
Serial.println(offset_y);
#endif
uint16_t ydn = DspHeight - 1,
yup = 0;
float fx = 0.0,
fyup = 0.0,
fydn = (float)BmpHeight - 1;
if (my_dir == OUT) {
yup = ydn = DspHeight / 2;
fyup = fydn = (float)BmpHeight / 2;
// Sweep the display vertically (up or down)
for (uint16_t y = 0; y <= DspHeight; y++) {
if (my_dir == IN || my_dir == OUT) {
dir = 1 - dir;
// Prefill the pixel colors with the background color (black in this case):
memset(PixelColor, 0, DspWidth * sizeof(*PixelColor)); // Fill background black
// Display_image is true if the vertical sweep is withing the image boundaries:
bool display_image;
switch (my_dir) {
case UP:
case DOWN:
display_image = y >= offset_y && y <= DspHeight - 1 - offset_y;
break;
case IN:
display_image = yup >= offset_y && ydn <= DspHeight - 1 - offset_y;
break;
case OUT:
display_image = ydn >= offset_y && yup <= DspHeight - 1 - offset_y;
// Don't gather image pixels if we're not within the image boundaries.
if (display_image) {
bool done_x = false;
uint32_t i = (dir == UP ? (uint32_t)(fyup + 0.5) : (uint32_t)(fydn - 0.5));
uint32_t r = BmpImageOffset + (BmpHeight - i - 1) * (BmpWidth * BmpDepth + padding);
// Sweep the image horizontally
BmpFile.seek(r);
for (uint16_t h = 0, i = 0; !done_x; h += BUFFPIXEL) {
uint16_t size = BUFFPIXEL;
fx = 0.0;
if (h + size >= BmpWidth) {
size = BmpWidth - h;
done_x = true;
BmpFile.read(SdBuffer, size * BmpDepth);
for (uint16_t p = 0; p < size && fx + skip < (float)size; i++, p++) {
fx += skip;
uint16_t buffidx = BmpDepth * ((uint16_t)fx);
uint16_t x = i + offset_x;
switch (BmpDepth) {
case 1:
PixelColor[x] = SdBuffer[buffidx] >> 3; // red
PixelColor[x] = PixelColor[x] << 6 | (SdBuffer[buffidx] >> 2); // green
PixelColor[x] = PixelColor[x] << 5 | (SdBuffer[buffidx] >> 3); // blue
break;
case 3:
PixelColor[x] = SdBuffer[buffidx + 2] >> 3; // red
PixelColor[x] = PixelColor[x] << 6 | (SdBuffer[buffidx + 1] >> 2); // green
PixelColor[x] = PixelColor[x] << 5 | (SdBuffer[buffidx + 0] >> 3); // blue
break;
if (dir == DOWN) {
fydn -= skip;
} else {
fyup += skip;
Tft.setCol(0, DspWidth);
if (dir == UP) {
Tft.setPage(yup, yup);
yup++;
} else {
Tft.setPage(ydn, ydn);
ydn--;
Tft.sendCMD(0x2c);
TFT_DC_HIGH;
TFT_CS_LOW;
for (int m = 0; m < DspWidth; m++) {
SPI.transfer(PixelColor[m] >> 8);
SPI.transfer(PixelColor[m]);
TFT_CS_HIGH;
float time_sec = (millis() - time) / 1000.0;
Serial.print(time_sec);
Serial.println(F(" seconds"));
boolean bmpReadHeader(File f) {
// read header
uint32_t tmp;
if (read16(f) != 0x4D42) {
Serial.println(F("Incorrect BMP file signature"));
return false;
// read file size
fileSize = read32(f);
// read and ignore creator bytes
read16(f);
read16(f);
BmpImageOffset = read32(f);
// read DIB header
tmp = read32(f);
BmpWidth = read32(f);
BmpHeight = read32(f);
if (read16(f) != 1) {
Serial.println("Planes != 1");
return false;
BmpDepth = read16(f) / 8; // Bytes / Pixel
if (BmpDepth != 1 && BmpDepth != 3) {
Serial.println(F("Unsupported color depth"));
return false;
if (read32(f) != 0) {
Serial.println(F("compression not supported!"));
return false;
return true;
// These read data from the SD card file and convert them to big endian
// (the data is stored in little endian format!)
// LITTLE ENDIAN!
uint16_t read16(File f) {
uint16_t d;
uint8_t b;
b = f.read();
d = f.read();
d <<= 8;
d |= b;
return d;
// LITTLE ENDIAN!
uint32_t read32(File f) {
uint32_t d;
uint16_t b;
b = read16(f);
d = read16(f);
d <<= 16;
d |= b;
return d;
